Review and Measurements of Wyred4Sound DAC-2v2 SE DAC
johan
No doubt it is possible to make discrete stage of good quality but stating that op amps have inferior sound quality compared to discrete stage because of the "simpler" signal path, higher feedback or something else is simply BS.
The truth is this: discrete stage of the same or comparable quality as the one made with op amps will cost significantly more and I see no single reason to pay for it as it will not sound better.
I disagree. Discrete opamps have advantages over the monolitic simply because real estate is not limited.
An excellent whitepaper https://sparkoslabs.com/audio-op-amps-gain-seek-bandwidth/
Internal testing with discreete stage reached -114.4THD+N unweighted and I think that unmatched in all tested DAC (unbalanced at 2.1Vrms) (but with special LPS for 5V)
Krunok
Zg, Cro
And what kind of sound quality parameter is "real estate"?
Once that figure is confirmed here we can discuss it. Anyway, even if that would be truth I'm not willing to pay more money for a device that has few dB better THD+N as it simply doesn't make sense.
johan
I am talking about real estate simply to say that you can add more caps so you can have a 2 pole compensation as outlined in the whitepaper .
That makes the discreet output stage (discreete opamp in fact) better than mono IC.
I am not trying to make anyone buy a discreete stage , just observing that discreete can be better than monolitic . No excuses saying that discreet stage must be worst than monolithic. Thats simply not true
Krunok
Zg, Cro
Can you explain what do you mean when you say "real estate"?
Sure, it may be better than monolitic desing, but at what cost???
johan
Monolitic opamps are 4x4mm die , discrete can be 300mm x 300mm
g29
Found these RMAA (16bits) measurements by HD-Fever. This was the DAC-2 DSD SE, back in 2016.
[NOTE: The HD Fever review is for the predecessor to the DAC 2V2 using a previous generation ESS DAC chip]
VintageFlanker,
Thanks for posting the HD Fever review, never heard of that site before.
According to the HD Fever review, adding an external AC Power filter makes a significant improvement to the Noise Level (25dB), Dynamic Range (25dB) and Crosstalk (27.2dB) measurements. Something good to know if true assuming many audiophiles use AC filters.
Also FWIW, one thing that might be helpful to the readers is to add a comparison table in the review summaries documenting the manufacturer's published specs against the measured specs to show what values meet or don't meet the manufacturer's claims.
More AC Filter plots found here.
I read the article but he doesn't say what AC filter he used. This would be the first case I see that addition of an AC filter changed the output of a DAC.
g29
Hi Amirm,
Thanks for doing all of the bench tests. Very enlightening.
As for the AC power filter, I think he identifies it as the Isotek Titan GII. I don't speak French and had to rely on Google Translate.
"... The power supply of the DAC-2 DSD SE will be treated with an Isotek Titan GII filter so as not to penalize the performance measurements. ..."
"... Note that the Isotek Titan GII filter has an excellent ability to clean mains power, ie to reduce noise. ..."
"... Here is the measured floor noise measured at the output of the DAC-2 DSD SE when it is connected directly to a "disturbed" wall outlet and when a good mains filter is added, in this case an Isotek Titan GII. ..."
"... Given the sensitivity of the DAC-2 DSD SE to the mains current and the problem found on our test bench, it is more than likely that this score is penalized by the residual that the Isotek Titan GII filter can not correct by nature. ..."
"... Measurements with lower scores are related to the problem of the electric current that the Isotek Titan GII filter can not completely solve. ..."
It would be great to know if a good AC filter actually addresses the issues in the DAC2 DSD-SE and the DAC 2V2 DSD-SE versions or if the noise was an artifact of his local AC power.
VintageFlanker
Paris
I liked HD Fever a lot. But Nicolas Becuwe also said (I believe it was the Oppo HA1 review) that a different power chord changed DR, SNR etc... But without publishing measurements of this very important statement...
Music1969
I wonder if they had some ground loops that got changed with the use of that Isotek filter.
Could an AC filter make a ground loop problem worse? Increasing the impedance and increasing AC leakage currents?
g29
Numerous places in the article he mentions a "discovered mains power problem" on their bench but the exact cause and nature of the problem is either not articulated, is lost in translation or this reader wasn't able to find. He also mentions that their AC filter limited because it is passive and does not control voltage, amplitude nor shape of the sign wave if that is of any clue to the noise problem (distorted voltage, amplitude and/or shape).
Rohandor
Amirm I liked to read your reviews, they looked like very professional and objective. However i need to reply to this topic and your measurements. It is because i took a risk and changed my topping d10 to wired 4 sound dac 2 (older version). I suppose version from the topic is just better than worse but what i have noticed when did the change was much deeper soundstage and easier to listen sound. Generally it sounds great, much better than topping especially when feed with cd player. Even my wife did notice it and she is sceptic about hifi. Therefore i could not agree with your approach in terms of evaluating gear. It looks like not only sinad matters, if it was topping d10 would beat wyred 4 sound without any doubts. However i must agree with one remark from you, this dac is sensitive to power source. When i turn on LED light powered from same socket i get broooming. To sum up i really would like to understand how your measurements really reflect sound quality in terms of listening to music on tested gear because based on my tiny experience ranking you build doesn't tell me that.
VintageFlanker
Paris
Welcome,
It's alright. He doesn't need your agreement at all.;)
How did you feed the D10 with a CD player already?
Did she noticed the same from the kitchen? If not, this anecdote can't be validated.
No one said it was the case...
You should have started and stopped there.;)Joke aside, I widely suggest your read this post.
jsrtheta
Colorado
Uh-oh.
Rohandor
Welcome,
I was really sharing the same approach to gear like, facts matters meaning what can be measured the rest is only legend. However this time i found W4S sounded much better than topping D10. For me it is obvious but still I don't mind anybody saying different we all have different tastes and hear differently. What interest me is how can I use reviews and measurments in this forum.
SIY
Alfred, NY
As long as you make sound evaluations with peeking (not ears-only), you'll come to all sorts of incorrect conclusions. The reviews and measurements will tell you how something sounds (or doesn't sound), not how something "sounds."
jsrtheta
Colorado
You first have to establish that there is a difference in the sound. Meaning you have to do a double-blind test and establish you, or someone, can reliably tell the difference between these DACs.
Until you do that, correctly, you have no data to support your conclusion.
Rohandor
Well facing your replies that my feelings are only feelings nor anything reliable I agree with you - I can not say that I made any measurment basing on any measuring regim etc. However there is still difference in how I hear 2 different settings which differ in tonality, sound stage, ease of listening despite measurements saying opposite.
So to make long story I can see that in audio gear there is something beyond measured sinad, linearity or dynamics, I can imagine that combining all gear together with lowest sinad would result in low sinad overally but it does not mean you will like it. Maybe measurements are not all you need to evaluate quality you are looking for.
SIY
Alfred, NY
I notice that you have completely ignored the concept of determining if the "differences" you think you have are actual audible differences. Until you do that, you're chasing ghosts and fairies.
