Esp3n89
- Joined
- Mar 4, 2019
- Messages
- 12
- Likes
- 1
Dammit i have no experience with soldering, maybe the solution is to get a case
The led on the Atom is so dim compared to how bright the led on the Khadas is
ASIO, WASAPI..Those words fly right over my head ahahahahahahaha!
i just installed the Khadas in the USB port on the back of my PC, put the RCA cables in it and on the Amp.. and then plugged in the headphones, on low gain.
So set it to 32 bits and 44100 on Windows, put the buffer and latency on the lowest possible.. if any problem occurs increase it a bit?
i had to install the Thesycon-Stereo-USB-Audio-Driver-V224 because i wasn't getting sound on my Windows 10 @brornstron , what case are you using?
A friend linked me this on Discord and said it improved his audio quality on Foobar2000,
anything else i can install or change on Windows and common programs to get the best audio out of them?
does firefox/youtube sound goes through the Thesycon-Stereo-USB-Audio-Driver-V224 i installed or will use WASAPI because of Windows?
Buffer and latency isn't the most important thing to keep as low as possible unless you work with audio recording and especially then recording a track on top of a track you play back. A lot of video players today also automatically compensate. Games not so much. Especially competitive ones, but there is also the display latency which usually is around 10-20ms.
