democles
- Joined
- Feb 3, 2019
- Messages
- 10
- Likes
- 9
I also had issues with it disconnecting/connecting repeatedly. I fixed the issue replacing the usb-c cable with just a basic amazon one. The cool patterned one that came with it was the issue for me it seems!
I had te same,but not with the cable it came with.
The KTB was not recognised on my player software.
I reinstalled the software and found out the cable was the problem.
I had another little thing.
When I feed the KTB with external power supply and start up my player computer Odroid C1+ at the same time together with the KTB
there is only distorted music on very low volume.
Wen i re-plug the power + (positive) on the KTB, sound is back and normal.
I think i have to make a relays on the power + to the KTB so it will start up after the player is started.
