Yes there is ASIO option for KTB and it will show up in ASIO capable DAW/Player software after you install the official driver package v2.24, don't use the evaluation driver v4.11.0 which is only meant to be used for firmware update and it will fail in playback from time to time because its evaluation software.
Win7 have not support for 2nd generation XMOS (UA class 2) therefor official KTB driver package v2.24, is needed, where in later versions of Win10 there is native UA class 2 in box but it will only support normal Windows sound system and WASAPI, so if one also need ASIO in Win10 use same as for Win7 the official KTB driver package v2.24.
Below is Control panel for my KTB on Win7, you can use it recheck numbers for your own system is the same and up to date, Revision field is the firmware and Version is the driver package:
When we at it to hinder most sample rate conversion suggest you set Windows sound system to 44,1kHz/24bit because most web browser or program sounds are of that rate, you can see the 24bit setting below and suggest one use the 32bit setting on Win10.
