bequietjk
- Joined
- Jan 4, 2019
- Messages
- 462
- Likes
- 474
oof no not connected to VIM. Does it have to be?
The tone board doesn't seem to work as a usb to spdif converter, the spdif can be set as output when used together with a vim board, not as a standalone unit.
I'm searching for a cheap usb to spdif converter and I've narrowed it down to the Topping D10, Fiio K3 and there are also cheap chinese CM6631 boards, I'm leaning towards the Fiio for its feature set.
...My goal for the tone board is to offload the data onto the tone board from pc and hopefully transfer those benefits over to another dac (my enog2). Currently doing some listening between both dacs and I feel like the tone board is more balanced throughout the spectrum of sound. This makes me wonder what effect it would have feeding into another dac.
Yes.Can the spdif input be used without a VIMS? Using the USB as power and spdif for audio input.
Why not : PC > USB Khadas TB > RCA to Project Horizon III > HD600PC > Topping D10 > SPDIF Coax to Khadas TB > RCA to Project Horizon III > HD600
Curious; has this effect been measured? Any relation to the Khadas drawing power from USB? Amir's measurements on page 1 were done with USB, not S/PDIF, correct?Amir talked about having an Audiophilleo in his chain of listening as a device that would properly/effectively transport digital media to the DAC, from the computer, and that the 'best digital tweak is a proper usb to spdif converter'.
I liked the outcome of that chain but the sound felt compressed. Its almost as if the music is being choked up and being forced through a screen door. You get all of the music, right. But it feels noisy.
Originally my plan was to utilize the spdif coax for my ENOG2 as opposed to the optical toslink ive been uaing for everything. The Topping D10 allows this USB conversion to spdif to happen so i bought one.
The sound change was tremendous with the d10 feeding into the enog2 and im smiling ear to ear. I pushed my tone board aside, right? Because just using it as a dac without the D10 wasn't complete for me. Then i found out you can use the spdif as input on the TB, hooked the D10 to the TB and out to my amplifier and achieved an even more polished and clear sound. Mind = blown.
This sound that I have finally come to can be achieved using different equipment of course, but the synergy of the D10 sending digital signal to the tone board dac seems to be creating this amazing path of audio that allows the amp to give your headphones the clarity you have set out for.
The Khadas Tone Board was selling at $99 right? Is it still available at that price?
