I did it many times… I rebooted, I reinstalled both drivers but no luck!
Very strange!
Flash Tone 1 right?
For windows
1. Remove all the drivers and app (even evaluation version)
2. Reinstall XMOS_TUSBAudio_eval_v4.11.0
-----Run the app ( V1.x --> If you don't see the Tone, that means you have V2.x)
----May need usb driver to see the Tone. I couldn't remember either V1 or V2 needs the usb driver in order to see
3. Must uninstall #2 (everything), then install Thesycon-Stereo-USB-Audio-Driver-V224.rar (if it sees the Tone, it would tell the version)
#2 ---- App can see V1 only
#3 ---- App can see V2 only (may need USB driver to see the Tone)
If you downgrade from V2 to V1, then need to install the app for that version otherwise, it won't see the Tone, however, any compatible usb driver still works without problem. The firmware app is for flashing and they are not compatible between the versions.
After flash, make sure to uninstall any Evaluation version, otherwise, music will stop randomly
V2 is actually better for SACD ISO where it can play very smooth in high bite rate compare to V1.
App and Driver:
https://dl.khadas.com/Firmware/ToneBoard/Driver/
Bin Files:
