Review and Measurements of WesionTEK Khadas Tone Board DAC
@willow, can you please tell me if the DAC emits noises or pops on its analog outputs when turned on or off?
I connected it to my Arcam rHead and set the volume to 12:00. There is a tick/pop on power on and power off on my Sennheiser HD-650 headphones.
I measured the levels using Audio Precision and I get this:
Turn on is around 2 second mark. Turn off is around 6.
Veri
After reading the entire thread my conclusion is this is more of a DIY component than a complete product. The turn on and off pop issue bothers me, especially after seeing one owner here become very defensive about it. I would have to say guilty until proven innocent on that one.
All it needs is a case though. Which will come very soon, likely.. pretty unparalleled performance in this price range.
Ron Texas
Is this mere annoyance or a speaker blowing shotgun blast? Thanks for the goods, Amir.
I will have to hook it up to my speakers to know for sure. Right now I have to go and paint our new shed!
Does the "hump" on the 9038 affect audibility or only measurements?
I don't know yet. Would have to devise a specific test case/tracks that hits in that region and then AB with another DAC that doesn't have that problem.
Zoide
What about purely in terms of dB / percentages? Is any part of that hump past the threshold of what is considered audible?
Silou
Is it possible to connect a little OLED Panel to the Board? If it its possible, what would be outputted to the panel?
Veri
It took some effort to tease out the same distortion in THD measurements but I finally got there:
In normal THD+N vs level it would not show up (or hardly at all). Shows the usefulness of IMD measurements.
As suggested I will write a new article with lots more data and then try to forward that to ESS and see if we get an answer.
Hey amir I was randomly reading this older blog post http://www.itsonlyaudio.com/audio-hardware/wm8741_vs_ess9023/
Is it me or is that the infamous ESS 'hump', from a ESS9023 chip no less.. (graph chip annotation is wrong, it's the --23 not the --18 chip).
I really wonder what the hell causes this ever returning glitch.
Xyrium
Anyone use the SPDIF connector on this for an output, or is in input only? I realize most of these aren't reconfigurable, but.....
Veri
I think it can be output if you program it.
Xyrium
Thanks guys. I'll go through the Wesiontek website to see if I can find something on this.
Edit: From their website: "1 RCA for S/PDIF in or out."
Looks like it either makes the determination itself, or can be configured. Sorry I missed this earlier guys.
From what I recall, this is only possible if you use their CPU board. The generic version doesn't support both directions.
Xyrium
That makes sense! Thanks Amir.
Veri
@amirm
Do you know if it would be possible to select USB or USB input via a switch? I would like to use the USB to read files from my SMSL DP 3 et my CD drive from the SPDIF.
Dominique
The USB will only accept a direct USB connection to phone, pc or compatible device. Not something like a hard drive.
