Assuming Kingwa is already aware of the bad publicity ASR did for AGD, I don't think the guy is gonna send something to be measured here anytime soon.If you somehow managed to persuade them to send a unit to you, you should ask for the AS-1 DAC. It is supposed to be a dig on ASR (AS = Audio Science). Let us see if Kingwa can actually engineer good stuffs or it was all talk.
Everything looks OK inside, distance from DAC's and analogue components till transformers is generous, plenty of caps to get rid of the ripple & noise, so not sure what might be wrong there.
Longest URL ever?
Yup. Works pretty much always.If you delete '?_' and everything following you'll get an equally functional URL
If you do an eBay search for 'Dual ES9038PRO' you get lots of no-name listings for the main PCB in this thing. I would not be surprised if the the only "engineering" Weiliang Audio has done is to engrave their name on the enclosure and swap the op-amps.
I could be wrong though.
Disappointing to see such dismal measurements on a dual chipped design. Thanks for fulfilling the curiosity of a lot of people though !
Looking at the measurements, seems that it has some serious issues with harmonics when it comes to THD and FFT measurements.
Anyone with insights into what might be the most common reasons for these manifestations in DACs ?
If you do a longer search on Taobao, there are actually more than 2 designs of dual-ES9038Pro chipped mainboards / DACs. I link here 2 I have seen , there might be others too.
https://item.taobao.com/item.htm?sp...3IL63s&id=569563397923&ns=1&abbucket=3#detail
https://item.taobao.com/item.htm?sp...3IL63s&id=607678045974&ns=1&abbucket=3#detail
The product of the developer of the decoder you linked has been measured before (before I got 555) (single 9038Pro). The results were very bad. He is not good at dealing with power noise. But I did not measure this Dual 9038 Pro product. He has lost my trust.
You mean the 杰米音研 M2 ? Good to know that you have measured that !!
The layout of that seems pretty poor. The power supply being so close to the DAC chip while the master clock being placed to far away.
The DAD3 seems much better laid out. The power supply is mounted on a separate board from the main chip board and and probably be further isolated with a metal separator shield plate. The Master Clock crystal seems much more appropriately placed too.
DAD3
