- Thread Starter
- #21
And a subjective review by Z:
Does it work on Ali? The link works fine for me on desktop and mobile (both on the official app and Chrome)."Oops, this item is unavailable"
This crap comes up so often in the last time. Does anyone know how to fix this?
I found out that the problem is my home country. I live in Germany and a lot of sellers do not want (or can?) ship to Germany. If I select United States or even Austria it works fine. This really sucks, because I have to buy the items from sellers that do ship to Germany and most of the time the items are more expensive.Does it work on Ali? The link works fine for me on desktop and mobile (both on the official app and Chrome).
Yeah looks like some countries are restricted and apparently it works if the seller ships from warehouses located in Russia (some sellers have them). Unfortunately there is no Russian warehouse option in this case.Its a country restricted sale. Not only Germany.
And now look at this, including a DAC and a linear PSU:
https://m.shenzhenaudio.com/smsl-m8...e-amplifier-p1-linear-power-w6-cable-kit.html
It's sort of difficult to get a picture of the internals. You'd have to desolder the connectors to get the board out of the case. The board is one sided and all the internals are on the top side. The soldering is very clean from what I saw when I opened it up. The bottom plate of the case fit perfectly (no movement) into a groove machined in the case, which is indicative of tight tolerances. It's a surprising effort for soething that's purely cosmetic, and most people wouldn't notice it anway.It looks like it measures pretty well, under most scenarios (I'm not sure I understand that huge output resistance; maybe some naked internals could help). Basically, if one upgrades the internal volume potentiometer with something better, then it gets quite a decent headamp there.
One thing I should note is that the volume pot on my unit gets scratchy over time. I have to clear it by turning it back and forth while powered off every now and then. I'm not sure if that's just my unit or if it's the same of every unit.
I do like that the distortion curve starts low at 1W. A lot of the other amps' distortion curve don't start dipping to low levels until past 10W. I like listening to my music at moderate levels.
