Yes, but pls. consider that - along with the unit, you get a set of 24-bit high-resolution pics of the Bodensee (Lake Constance) ...
Just one sample:
Oh sad. Found this. There used to be jumper for dc coupling in v200 and some other models.
That's not completely true.(Or you are talking about something different.)DC coupling in a headphone amplifier, without rapid DC protection circuitry is foolish. With the obviously high rails (>50V), delicate headphones could be vaporized with assymetric input transients etc.
Not only that, any offset, however small will be amplified by a DC coupled connected amplifier when used as a preamplifier and either a) trip the amplifier's DC protector if it has one or b) cause significant voice coil displacement in any connected speakers.
Also DC won't cause coil displacement unless there's constantly increasing DC level. Coil is inherently AC coupled. With any given DC offset, it will eventually settled back to the center. Coil heating is a different story.
One extra point, even when implementing DC blocking circuit, one would design in such way that it doesn't hurt frequency response at 20hz. Merely 10k and 2.2uF will give about 0.5db loss at 20hz.
-2db at 20hz is a bit too much for an amplifier tbh.Ah, no. DC causes a speaker VC to shift and stay in that slightly offset position until the DC is removed. (or the VC overheats and burns out)
As for the amplifier concerned, if the output stage is DC coupled to the headphones, there should be a DC protection circuit and relay, as it clearly is running very high voltage rails (>50V). (Do the math on the output values and loads posted above). Likely in a balanced bridge type arrangement with perhaps a single supply rail so the net offset is zero. It's unlikely they'd be running split +/-60V rails as that would be insanity in a headphone amplifier.
Using inter-stage coupling capacitors is perfectly fine, and unless calculated incorrectly, they should not affect any legitimate musical content. Consider people who may use one of these alongside a phono preamplifier and the last thing you would want is infrasonic rumble/arm resonances being amplified- a very quick way to destroy expensive headphones.
Anyway, this is conjecture on my part, I haven't seen one or inside one.
Pot can be used as the R in the rc circuit. In Violectric amps it seems to be ALPS 100k ones. So idk why is that -2db at 20hz.And you need to consider the following stage impedance, especially if it varies (pot), or connected load...
It is. Indeed to make sure nothing was wrong in my setup, I put the AP in loopback mode and it was solid flat.The AP's AC coupling is flat to <10Hz I believe, and the FR sweep would surely be using DC coupling.
That is a very good find. They should fix the specs to reflect that. It sure caused me to lose some time testing and retest to see what is going on.So...no jumper for dc couple.
