I read the Fostex T50RP would have issues with the Topping NX4 though. Makes me curious. Is there a reason why that might be the case?
It might run out of current if you listen particularly loud or have modded it, since that reduces its sensitivity.
The spec says 92db/1mw so it would seem ear splitting loud even with the NX4. Of course, specs don't tell the whole story. I may have to try just to see.It might run out of current if you listen particularly loud or have modded it, since that reduces its sensitivity.
If anyone is interested to buy Topping NX4 DSD, there is a new Drop run for 136$.
https://drop.com/buy/topping-nx4-dsd-dac-amp
Tell me about it. I got my Senn HD 6xx after 2 months, but that was during the initial Covid onslaught.
Thanks again for the leads. I love the community for its helping nature.
Re. SoundShanling L2 made my IEMs sound much more clear, the soundstage is leading to subbass and back through highs to support the mids ... JustKidding
Im so lucky to have found you. Do you still own SP200 and NX4 and can you compare these two in sound? What headphones do you use?SP200 here, honored the price match and send replacement with better volume pot. 10/10 service, really nice people.
Hey. NX4 is portable USB amp and SP200 powerful desktop amp. Why compare these two exactly?Im so lucky to have found you. Do you still own SP200 and NX4 and can you compare these two in sound? What headphones do you use?
I was dissapointed in the soundstage of the ifi hip dac and searched for an alternative. the sp200 is the best amp I know, therefore I wanted to know how much I would miss on when I get the NX4Hey. NX4 is portable USB amp and SP200 powerful desktop amp. Why compare these two exactly?
In any case I no longer own SP200, sorry. Upgraded to Topping A90 which is not yet delivered![]()
About right, mine also can last around that time, maybe 8 hours more since I didn't play it loud.The DAC + AMP battery runtime is about 7-8 hours on my NX4
I had been using it with my iPhone Xs for some time with the Menoova cable (http://www.meenova.com/st/p/lgtnmuc.html) without any issues.
Now it doesn't work anymore, could be since the latest iOS update (i'm on 13.5.1) but i don't know exactly since when. With Android and PC no issues.
Anyone know this issue and maybe even a solution?! It's basically bricked for me ;-(
Looks like there was an upgrade to the cable? From the link you posted:
New upgraded 2018 version that works with iOS 10.3, 11.x, 12.x and future iOS upgrade.
Bought the cable beginning of 2020 and it worked with iOS 12, so I'm sure i have the newest one
I just ordered that cable (thanks for the link.) I will let you know how it works.
One other thing, have you cleaned the connector port on the iPhone? I have iPhone Xs also, and I found that the hole sometimes gets "stuff" in it that prevents connectors from working well. I found it is usually dust and pocket lint. After cleaning, things work again. I use a magnifier, a pin, and some contact cleaner to get anything out.
NX4 should do fine with those.Hello!
Im considering buying Topping NX4 but im not sure of that just because the output power. Im currently using xduoo x3ii which provides 212 mw/32 ohms while Topping provides 293mW a 32 Ohms.
My headphones are Beyerdynamic dt1770 pro and AKG k712 pro, and I was offered a Xduoo xd-05 too.
What should I do???
There's no known big revision of NX4. So whether its apos, amazon or some other, it should be the newest version. No worries. Apos has the best service and 1year extra warranty though.Sorry if this has been asked before, but are there any different revisions of the NX4, and if so where can I get the latest version? Apos Audio? Or if there is no revisions then does Amazon have a similar 2 year warranty as Apos Audio?
