- Thread Starter
- #721
On DX3 Pro using the remote, you just press line out twice. Doing that from menus on DX7s should be possible too but likely not trivial to figure out.
On the DX7s, pre-amp volume controlled mode is engaged by pressing the big button in the centre of the arrow cluster on the remote.can t get just pre amp volume controlled
The first time you hit it, it will go into variable line out. It requires a second press to go in 0 dB mode. While I appreciate the issue, I have not had that problem with my setup.I feel it is very dangerous Topping has the line out button on the remote.
If I hit it by mistake, I probably will blown my speakers if I use a power amp & passive speakers.
Has Topping disappeared? Several days have passed since HP was closed.The Toppings website had went poopoo
The Topping website doesn't always load on the first try. Their web site design and management staff apparently are not as technically competent as their DAC design staff - which to me is better than the reverse where companies like Sch**t scrimp on the hardware design, but don't miss a beat on marketing and image building.What are you talking about?
http://www.tpdz.net/
I pulled the trigger on one of these used, it powered up and allowed me to switch between inputs, then I long-pressed the volume knob and now it greets me with the ERR : DAC_R message. Tried factory reset to no avail. Is it the "dumpster mode"?
I wish I could find an scientific explanation of this phenomenon as both DACs measured very close here. I am running it at about -20dB attenuation into an external power amp and Khadas at 0dB into a (passive) preamp, perhaps it has something to do with it.
