Is it a discontinued model? Or is it a temporary suspension of production due to a shortage of semiconductors?Looks like these are sold out. Is a new version coming soon?
But Shenzhen Audio seems to have stock.
Increasing the gain usually increases noise also.And if I understand it correctly: when you lower the volume with the dx3pro digitally then the noise floor gets worse. Since the dx3pro has a SNR of about 117dB minus the 40dB digital attenuation would mean you now have a SNR of 77dB. Please correct me if I‘m wrong.
Edit: Or 117dB plus 9dB for high gain —> so 86dB instead of 77dB?
I see no stock anywhere.Is it a discontinued model? Or is it a temporary suspension of production due to a shortage of semiconductors?
The volume of DX3Pro is not a general volume but a rotary encoder. In the structure inside, many electrodes are printed on the circumference of a disk-shaped insulating substrate, and the rotation angle is detected by rubbing it with a mechanical brush.I see no stock anywhere.
Hopefully this is an opportunity to refresh the model.
I like the product concept, all in one unit including a remote, Bluetooth and headphone amp for around $200, but this thing was plagued with issues.
Personally I got one with a broken volume knob. Twisting it one way would change the volume in the wrong direction for a step, then it would go the right direction. I encountered a DX7 Pro that did the exact same thing. I swore off of topping after that but I might give them another shot if they sort out these issues.
Interesting, thanks for explaining the design of the knob.The volume of DX3Pro is not a general volume but a rotary encoder. In the structure inside, many electrodes are printed on the circumference of a disk-shaped insulating substrate, and the rotation angle is detected by rubbing it with a mechanical brush.
Due to its simple structure, the behavior you point out will inevitably occur. It will occur again if you use it even if you replace a new part.
The frequency of occurrence is proportional to the number of times the dial knob is turned.
If you don't like it, use the remote control to operate it.
I know the structure and drawbacks of this part, so I usually operate it with a remote control.
Again? I have seen this posted somewhere. A lot of things are wrong in this video. Even the pdf for the dac chip is wrong. And there's no measurements shown after modification. I know it wouldn't measure any better.See what mod for Topping DX3Pro was made by an enthusiast from Ukraine.
Self-deception or simply making things worse.theoretically, such modifications can give a tangible increase in sound quality by ear? or is it just self-deception?
Browse DIYaudio forum and you see mostly such things very few industry experts, lots of hobbyists who think they know things.some people who make mistakes are too convincing that they are right. it is confusing.
What difference that you noticed?Just upgraded from my age old SMSL M3 to this beauty.
Didn't expect a huge difference, but it was noticeable within 5 seconds. Very pleased so far.
Improved clarity, more balanced sound, better bass.What difference that you noticed?
Not sure if this is the right place to ask this, but does anyone have this problem with their DX3 Pro?
Whenever I touch/move it the usb disconnects and makes a clicking sound. Its terribly annoying since its so sensitive to any sort of movement
I thought DX3 Pro was discontinued, but it reappeared as DX3 Pro +.
