Review and Measurements of Topping DX3Pro DAC and Headphone Amp
Toku
Japan
Looks like these are sold out. Is a new version coming soon?
Is it a discontinued model? Or is it a temporary suspension of production due to a shortage of semiconductors?
But Shenzhen Audio seems to have stock.
RHO
Belgium
And if I understand it correctly: when you lower the volume with the dx3pro digitally then the noise floor gets worse. Since the dx3pro has a SNR of about 117dB minus the 40dB digital attenuation would mean you now have a SNR of 77dB. Please correct me if I‘m wrong.
Edit: Or 117dB plus 9dB for high gain —> so 86dB instead of 77dB?
Increasing the gain usually increases noise also.
Like in this graph:
You see the jump in THD+N between low gain and high gain. I think this is predominantly the increase in noise.
Lowering signal amplitude also brings the signal closer to the noise.
ClosDeLaRoche
I see no stock anywhere.
Hopefully this is an opportunity to refresh the model.
I like the product concept, all in one unit including a remote, Bluetooth and headphone amp for around $200, but this thing was plagued with issues.
Personally I got one with a broken volume knob. Twisting it one way would change the volume in the wrong direction for a step, then it would go the right direction. I encountered a DX7 Pro that did the exact same thing. I swore off of topping after that but I might give them another shot if they sort out these issues.
Toku
Japan
The volume of DX3Pro is not a general volume but a rotary encoder. In the structure inside, many electrodes are printed on the circumference of a disk-shaped insulating substrate, and the rotation angle is detected by rubbing it with a mechanical brush.
Due to its simple structure, the behavior you point out will inevitably occur. It will occur again if you use it even if you replace a new part.
The frequency of occurrence is proportional to the number of times the dial knob is turned.
If you don't like it, use the remote control to operate it.
I know the structure and drawbacks of this part, so I usually operate it with a remote control.
ClosDeLaRoche
Interesting, thanks for explaining the design of the knob.
JohnYang1997
China
See what mod for Topping DX3Pro was made by an enthusiast from Ukraine.
Again? I have seen this posted somewhere. A lot of things are wrong in this video. Even the pdf for the dac chip is wrong. And there's no measurements shown after modification. I know it wouldn't measure any better.
Asma
theoretically, such modifications can give a tangible increase in sound quality by ear? or is it just self-deception?
Asma
some people who make mistakes are too convincing that they are right. it is confusing.
Kennedy
Just upgraded from my age old SMSL M3 to this beauty.
Didn't expect a huge difference, but it was noticeable within 5 seconds. Very pleased so far.
Cacophony
Will it be safe to run an Atom via the lineout (opa1612 stage) when either the opa2140 or transistor stage is broken?
The headphone out makes a massive loud click when headphones are connected and shuts off, but the lineout from testing seems not broken.
Sorry for reviving the thread, I haven't been able to use my dx3 for almost a year, got charged import duties for the replaced unit and didn't bother to get another, but apparently that was a mistake and I shouldn't have had to pay duties.
Update: I shouldn't assume it's still have opa2140 since they send me a "4.7ohm" version of the v1 version
Kennedy
What difference that you noticed?
Improved clarity, more balanced sound, better bass.
Well, it's been 3 weeks. I think it's safe to say I lost a good portion of my hearing.
Used to have my samsung music player on volume 3 and enjoy music just fine. Now I need minimum 4-5, 3 sounds almost like whispering.
Fluxed
I recently reset my Topping dx3 pro but now it stays on all the time even when the PC and TV are switched off, before it use to go off on its own anyone know the setting to make it auto switch on when an audio signal appears and off when nothing ?
I did try auto button with A-0 and A-C but didnt work
TLDRonin
Not sure if this is the right place to ask this, but does anyone have this problem with their DX3 Pro?
Whenever I touch/move it the usb disconnects and makes a clicking sound. Its terribly annoying since its so sensitive to any sort of movement
Fluxed
Not ever had that issue, but that sounds like its a hardware fault. Have you tried to try a different usb cable and also try the power plug into a different electrical socket.
While you are checking the power plug check its fitting in firm into the back of the topping amp and its not loose.
Toku
Japan
I thought DX3 Pro was discontinued, but it reappeared as DX3 Pro +.
I think that the missing AKM products such as AKM4493 were changed to other chips and renewed and reappeared.
This solved the question of the release of PA3s.
The FB Topping page states that it will be officially announced on September 28th at 10 AM.
