Veri
- Joined
- Feb 6, 2018
- Messages
- 9,666
- Likes
- 12,285
It was posted 2 hours ago..Haha, thanks. I have been pretty excited for this review and completely missed it![]()
Or maybe not.In addition, the output impedance of it is lower than 0.1 ohm by design. The retail version may have an even lower value.
It was posted 2 hours ago..![]()
That will be very interesting, this has such good basic and predictable normal performance that any badness introduced will be obvious.Yes, I forgot to mention that this also has Bluetooth input. Will see if I can test it a bit.
Maximum output power at 32ohm was what, just over 0.5W? That's half of what they promised?
That smooth exponential rise is just the noise floor of the DAC dominating. So it is not an offset error as we see many times (with jagged output). All else being equal, I rather seen noise here than non-linearities. I think this is a limitation of the AKM DACs relative to ESS parts.
I'm not sure the chip is to blame here. We saw 20-bit linearity with the RME Adi-2 DAC, which uses the lower spec'd AK4490.
Shouldn't the AK4493 used here be capable of at least equal performance when optimally implemented?
(I don't believe this is an audible concern in any case, btw.)
The RME is a $1k device and can allocate a bigger chunk into power filtering/regulation though. The linearity is bad because of noise, not because of inherent non-linearity issues. If this device was $400-$500 we could have a way better power stage / power adapter.
As it stands, for its budget it is killer, I think. The EL Dac had better linearity but it has no amp stage, no bluetooth, no remote...
https://www.audiosciencereview.com/...w-and-measurements-of-schiit-modi-3-dac.4742/I'm not sure the chip is to blame here. We saw 20-bit linearity with the RME Adi-2 DAC, which uses the lower spec'd AK4490.
I think price is getting a little bit too much mixed in to the reviews, coloring the whole review.
Just objective performance is what I am after reading, then I can judge myself if the price is good or bad. Also price changes sometimes after hand, then the review gets kind of obsolete if the price is too intertwined in it.
The sudden unimportance of resolution (linearity in bits) in this review was a bit surprising for me. This was kind of a big deal in previous reviews, as I have interpreted it.
(I love the reviews, just a small note this)
I know you're joking but AKM has an image on its product page that shows which chip has better sound quality.AK4493 should be better, it reveals the whole face in full color.
