Starting to regret my massdrop order the other day..hmm. Wonder if I can/should cancel.
Sorry, what?I heard the vicar of Notre-Dame got his DX3 Pro on Massdrop too.
Sorry, what?
Definitely go through Topping. They will take care of your expenses of shipping and will get a faster chance at figuring out what is going on with such units.I bought it from AliExpress, should I bother the seller or contact TOPPING directly?
It is not a QC problem when the unit fails after you buy it. It is some corner case design issue that is causing failure in some units.I really enjoyed the functionality and sound quality of this device but QC is probably the worst I've ever seen when it's actually breaking people's equipment.
FYI, both of my units continue to function reliably including the second one that was supposed to be broken as said by the member.
I am pretty sure there is some kind of race condition that causes failure that has to do with how the unit is used. Figuring this out will be very hard for Topping.
Thanks. Is the static from the RCA very faint or loud?
That's pretty nasty. If it occurs frequently, you should sent it to Topping for analysis.
Have the same amp lol, i red that its preamp is not that good and that is worth to bypass it, please test it and write back (i have a Tannoy revolution xt6f which i admire and recommend every time)
so i have this setup now and after a while i must say that it is performing much better with Topping as preamp, dac added more detailed sound (compared to dacmagic 100) and i can hear more from the same tracks. Preamp gave very balanced sound and overall i'm super happy with this trio (nad tannoys and topping).
Here the video showing my problem:
Aliexpress seller wants to send the device back but shipping costs could be quite high. I'm also waiting for Topping's feedback if there is any other solution possible.
I have already ordered a self-learning remote to mitigate risk that speakers accidentally burn my ears. It rather looks easy to (at least) disable possibility to enable fixed line-out via remote. Or maybe the menu section (and remote controller part) is hardcoded in other place than firmware - then indeed it wouldn't be possible wothout hardware changes (I still keep my fingers crossed it could be somehow changed with another firmware release)
What about filters bug? There are 6 options available via remote (F1-F6) and only 5 via settings menu (F1-F5). It hasn't changed after update to 1.04.
Hello guys, the amplifier that carries the DX3 Pro is powerful enough to drive the somewhat k612, thanks
Yes please!I do. Do you want the 6 kHz at -6 dB too?
Without knowing the exact design issue, there is no way to know what triggers it. If you have had yours for a few months with no problems, chances are good that you will be good as I have been with the two I have.What's a corner case design issue? Would that mean if my unit doesn't have that issue I shouldn't worry and how would I know if it does?
