Hi Rigel, I am new on this forum, but I also ordered the D90. Do you already have some comments about what you think of it? There are not much online reviews as yet, so every impression counts.
Hello AndyLu. Welcome to the forum.
I tell you. Sorry for the English, I use a translator.
I always use the PC to listen to music and so far I have been using an M51 DAC. It is a good DAC, but its USB input is not good and that is why (and because I also like DIY and experimentation) for some years I have been experimenting with several USB / AES digital interfaces USB conditioners, power supplies etc. . To take advantage of it.
With some I have done well and with others not so much, but with the D90 I have been surprised at how good the USB input is, simply using a simple cable, this statement may seem absurd, but I am so used to using various devices to take advantage of the M51. The USB input has been greatly improved since 2012 that the NAD M51 came out.
The D90 is very good, I doubt that you are not happy with the purchase if you are looking for transparency and high resolution in the sound as it happens to me. You can hear clearly, the separation between the different sounds or instruments and the low level details are perceived more clearly.
I bought the D90 thanks to the Amir test, because I wanted to check personally, if my personal taste on the sound, could correspond to a good technical execution. Now I could say that it has been.
When comparing the M51 with USB / AES interface, linear power supply etc. With the D90, the latter I appreciate more detail. Details are heard in the songs I had not heard before. I am combining it with an SMSL SP200 and a Sennheiser HD800.
Using the USB input of the NAD itself, the differences are already quite wide in favor of the D90.
Even though the USB input of the D90 is so good, on the Topping website you can read that the best input would be the IIS, it is possible that you combine it with a Matrix Spdif 2.
In a review of the D70 that I have read, it is also commented that in his ears, the best entry of the D70 is the IIS.
I will comment if I encourage you to tray it.
I have not had problems with drivers, configurations or playback, although there are things that I have not yet tried. DSD files for example.
It has good exterior finishes, the machining is quality. And inside it is also well finished. I have not seen any bad welding for example or bad termination. The buttons are solid aluminum, nothing plastic.
Anyway, happy with the purchase. I guess you will know the review that was announced in a thread of this forum. Just in case take a look.
https://soundnews.net/sources/dacs/topping-d90-review-a-genre-master/
