I didn't get you, NOS DAC? By the way, my SPDIF is Toslink.It doesn't always show bit rate, with usb i (v1.02) see 44.1-768kHz / 16/24/32/bits too, but for example with spdif 00bit.
And i'm sure you know D50 is NOS dac.
No, I mean D50 shows incorrect bit depth of 16 bit data as 00bit.Did you mean 00.0dB? I am talking about the bit depth.
Just connected Shinrico shd 5 via coaxial cable to my d50, much better SQ than USB output of Raspberry pi 3, but every time I'm touching any of my components static electricity kills sync with DAC (
Can anyone recomend a good power supply? For EU use. Ive seen a few "hifi" PSU's on Ebay, for like 50 bucks.
It's definitely an oversampling DAC. Pretty much any modern design DAC uses an OS filter for an accurate response and to get rid of ultrasonics.non over sampling ?
right ?
You can't have a proper reconstruction without some oversampling. Which is a necessity really for any proper DAC, otherwise the output will have severe aliasing. From https://www.researchgate.net/post/Why_do_you_need_an_analog_filter_in_designing_a_digital_filterOk, thanks for correcting.
I thought filters aren't oversampling but oversampling is for example 44.1kHz x X before converting it to analog signal.
I have set my D50 to filter 5, I find it the most transparent of all 'though differences with other filters are subtle but they are there.
What filters you guys prefer?
Just got one of these PSU's. Week to arrive after contacting seller about specs: 5V/3A + correct power plug for D50. Total was 75€ including s&h.
https://www.ebay.co.uk/itm/Zerozone-50VA-DC-LT1083-LPS-HIFI-Linear-Power-supply-for-amp-DAC-external-PSU/122115343477?ssPageName=STRK:MEBIDX:IT&_trksid=p2057872.m2749.l2649
Must be new piece placebo, but bass sounds more powerful vs 10600mAh powerbank
Ok I thought I might be crazy, I also agree that the bass increased substantially after powering with a Linear power supply similar to the above link.
I also use mostly 5 and also 3 depending of the music I'm playing. What surprises me is that playing the 2015 192/24 Van Halen remasters these filters also have an impact on sound, 1, 3 and 5 get cymbals to sound right, with the others they have the typical dull and unrealistic sound. I never thought these filters could affect sound even at high sampling rates,it makes no sense, a 192 Khz sample rate has an actual frequency response of 96 Khz, far beyond the reach of those filters.5 and 3.
edit:That's how two flat-earthers must feel when they meet for the first time.
Measurements or it didn't happen!
I just sprung for the D50 it's been playing PCM and DSD of various resolutions for several hours in a long loop. It sounds good with no clicks at format or resolution changes. Have not tested with higher DXD as I have only 358 DXD rather than 384 DXD files. I'm using Topping ASIO driver in Foobar, after I had trouble getting it set-up with WASAPI. Laptop plugged into mains and accessing files on NAS and PC over Ethernet, line out into Denon receiver.
My question: I want to connect this D50 (elsewhere) to a pair of AdamA7X powered monitors, set about 3 metres apart, any recommendations for rca cables to do this.
