Quick question for you folks. Is there a way to switch between outputs? Meaning Line Out Analog and COAX? Or can you only use one or the other at the same time?
I don't think this unit upsamples or downsamples (at least I have not found a way to do that on my D10, nor does the manual indicate such).They would all output at the same time
So if the output is not in the range of 44.1-192Khz/16-24bit PCM only, analog would output while digital will not.
The other day, I purchased from China and returned it to China because the SMSL M500 is defective. For the delivery from Japan to China, the Japan Post EMS is the easiest procedure and can be used at low cost.I posted a while back about an issue where my unit would randomly stop outputting sound (and wouldn't even be recognized by Windows) unless I left it unplugged overnight. Then it would work again until it wouldn't, usually in the middle of listening to music or watching a video.
Well now it seems like it's totally dead, I've left it unplugged for hours and plugged it back in and nothing. There's the little dot on the display so I know it's getting power, but Windows doesn't recognize it as being plugged in so I can't even adjust Windows settings or anything.
I guess my question is - I bought this thing a little over a year ago. If I sent it to Topping, would they repair it and send it back? Would it even be worth it to send it in? I'm almost considering just getting a new DAC if it's gonna cost a decent amount and take forever.
If anyone has experience sending stuff back to Topping, I'd love to hear it.
Ground loop or leakage current? They're a common problem with unbalanced interconnects, and usually not specific to the DAC but the system as a whole. They're not too hard to find and fix if you follow a systematic approach. Jensen Transformers have detailed instructions among their application notes.
What are you "cranking" up? An external amp? What amp is it? Is the amp dead quiet with other sound sources and just noisy when D10 is used as source?Using this out of a Mac mini and getting a bit off buzz when I crank it all the way up with no music.
Is that the exact same system (including cables) changing only the DAC? It's the sort of thing where the details matter.To be honest, I am not sure. When I run the Eitr to Modi 3 to my headphone amp, it is noticably quieter. Is that due to both being externally powered?
It doesn’t quiet sound like a normal ground issue.
Well my D10 died after 2 years, it just shows the dot and it is not recognized when i plug it in in any computer/different usb port. Does anyone have an idea how to fix it, Topping won't do that form me because i don't have a proof of purchase.
Edit: Hah i see a lot of people around the web have the same problem with D10. I guess this is a common issue so i'll stay away from it in the future.
You can measure voltages of LDOs (3.3V) + point with marking "1V".
Thanks братко, but my level of diagnosing failures in these kind of problems is very low. I'm kind of monkey here, very skilled in soldering and i can fix it if i see the picture and have instructions
