Odd question, maybe, but does anyone know how this DAC is filtering the HF noise when playing DSD?
It seems there is a hump at around 70kHz and -70dBFS. I know DSD has HF noise inherent in itself, but shouldn't it get filtered out by the DAC?
How much of a big deal is this HF noise feeding analogue gear down the line? Are speakers/headphones are too slow/resistant for these frequencies to cause damage at this level?
I've seen filter options on other products, even for their PCM side of things, but there is no option on this product.
Without wanting to set a course of a destructive never-ending round-about topic, I am not really hugely fussed about the DSD side of things in all fairness. Getting the digital loudness normalised across my music library, which ReplayGain does on the fly for pre-scanned PCM, is more important to me than a possible subjectively nicer sound in DSD, if it even exists as I haven't experienced it myself with this DAC and the equipment I have access to.
I am still in the process of working out which DSD to PCM conversion is the least destructive, and in plenty of cases the plain answer is to find a release of the same material in it's original PCM form, because it was just converted to DSD to sell something else!
Something else I noticed from this DAC and using the same PC it is connected to, to capture the line out, is that there is some audio band frequency noise humps that drop away when the display goes dim. This is without any music playing, just self noise.
Until I get a decent ADC and put it on another computer, I will hold off really discussing it too much, unless folks want to, as I think it might be more a product of the lousy onboard Realtek ADC interference from the USB side of things all on the motherboard, rather than anything actually to do with this DAC.
What I was trying to say is that there are two different sounding noise profiles, once when the display is bright, the other when dim, arguably with the dim noise being more prominent, lower pitch.
However, I also think that it's somewhere maybe in the method, like my onboard ADC is just getting and making noise from somewhere.
New forum member here. I'm currently using a dragonfly v1.2 from my laptop into a sabaj ha3 hybrid amp (upgraded Mullard valves).
Would the D10 produce a better sound into my sabaj than the dragonfly ? I've had it for three years so need an inexpensive upgrade. Headphones are Fidelio x2s and music is either Spotify premium or flac files via foobar. - Steve.
Based on this measurements I would say D10 is a better device but it is highly questionable whether you would be able to hear the difference through the valve (or any other) amp.
Surely the D10 being a newer device with a better chip than the dragonfly would suggest otherwise ? I'm not suggesting You're wrong. (Still learning about audio tech and where best to spend my money).
Your money would be best spent in better loudspeakers/headphones.
Indeed, however it should be said you do not go very far in your loudspeaker upgrades with the cash amount that equals those "low price-high performance" DACs ...
