Veri
- Joined
- Feb 6, 2018
- Messages
- 9,597
- Likes
- 12,039
Wow, excellent that does redeem the D70 in my book.It rose up to 112 dB.
Thanks for the measurements! And topping for lending it out!
...and then you have the D2 actual top-end flagship , but unless that thing mops the competition thoroughly, things like the RME and Okto will forever be encroaching on it as they offer a serious price/featureset at the price the D2 will be attempting to compete at.
How low is D70 jitter actually? Comparing to, for instance, RME ADI-2 DAC with its femtoseconds clock RME is also proud of?
Jitter is pretty boring as soon as it hits 'very good' range honestly. As soon as the worst offender spikes are at or under -120dB, they are already below audible!! But if we want to make it a measurement contest here you go.
Fourth place, RME ADI-2 with its proprietary SteadyClock FS
3d place, AK4118 receiver with good clocks as seen in the D70
(pretty sure this graph's comment was meant to say -120dB)
Second place, OKTO DAC8 with heavy ESS jitter suppressing using ASRC and once again good clocks
First place goes to SMSL VMV D1. It has an Altera cyclone FPGA with sole purpose being reclocking, uses the same AccuSilicon clocks as the D70
-170dB at its lowest point.
But like I started off my post. This is measurebating to the extreme. NONE of all four have any excessive spikes at all! You can't hear this!!
I would say no. The D70 has some spikes because it is shifted downwards -10dB in noise floor. In the RME those spikes are simply buried. Not saying the RME is not exemplary though, because it is.Putting audibility aside and just looking at those measurements, isn't the RME the best out of those 4?
That is not my understanding. See for example: https://cemarking.net/ce-self-certification/
But pitting the RME versus the DAC8 and the D1, I don't see how you'd rate the RME over them? Or am I missing something
When I ran a 1 kHz spectrum test, there was a spike at 45 kHz. Since the bandwidth of that test is twice as wide (90 kHz), that spike got included in the computation of THD+N in that graph. Since the spike is not audible and its level would go down with the test signal, it is not a very significant impairment. In other words, that graph looks worse than it should.
Well, output voltage. Depending on your power amp’s input sensitivity, you would lose at most 3dB if the DAC volume is -3dB, aka 1/2 the wattage.Nice. Do any measurements get negatively affected with -3dB volume? Can't imagine so, but maybe interesting to look at before you return the unit.
Would the standard digital filters in a DAC, which are typically applied from 20khz, make this a non-issue?Getting back to using the D70 --> Hypex NC400 -- the issue with such wideband by design (it's a feature, not a bug) is that the 45 khz spike will be amplified and sent to the speakers. Although there won't be aliasing concerns, given that the whole point of HD audio is to properly care for our "beyond nyquist" psychoacoustic concerns, we certainly want things to be clean up to at least 48Khz or so....
I have not succeeded in getting an M300....Would be nice to compare This one with the SMSL M300, same chipset (AKM AK4497) and symmetrical outputs...(Cheaper).
