Sorry Veri
Words came faster then I intended to ..
All I intended to do was to help trustlaw with a dac that works nicely with the X50D lvds out .. my mistake was to write a personal perception of that equipment then all hell broke loose..
I sincerely apologise to all offended!
No problem at all. happens to us all from time to time. But all I wanted to make clear, if you make use of standard USB connections on your audio gear, internally it also gets converted to I2S. This can happen synchronously or asynchronously, and usually there is very little jitter on USB connection (but there are exceptions, like older
Schiit modi 2 as a bad example). Usually USB is totally fine, so I would not recommend anyone to buy a special device for I2S. Your DAC already does this internally after all. It is audio manufacturers and audio
marketing that makes you believe you need this. Just accepting I2S input already makes you wonder if you should buy something that outputs it, lol. They create a need!
Now, on other forums like audiophilestyle or head-fi there are many claims that interfaces can sound "better" or different, sound stage wider and
more detail etc. On this audio science forum you will find very few people that will believe such claims, because there's no science to it, just beliefs. Anyway, thanks for listening and for the apology
have a nice day
