This is a review and detailed measurements of the Creative Labs Sound Blaster Z PCI Express Gaming and Surround Audio interface card. It is on kind loan from a member. The Blaster Z costs US $100 on Amazon with prime shipping.
The card is still in my machine so here is a stock picture of the unit:
It has some red LEDs that come on when powered on. Alas, that didn't help me much in getting it working. Despite said lights on first install, Windows did not recognize it and the 150 megabyte package of crapware from Creative refused to install anything saying there is no hardware. I almost gave up but decided to re-seat the board and try again. This time Windows did recognize it.
Installation of the crapware package was not smooth. It installed a bunch of stuff with yet another interface than their other boards. It added an auto-update which immediately told me there were critical updates available even though I just downloaded the rest of the stuff! For grins, I let it try to update, only to have it fail catastrophically with bad error dialog boxes, etc. Fortunately it worked. Well, kind of. Its ASIO interface would not work and kept saying the device was not there or some such thing. So I had to rely on ASIO4ALL layer on top of its low level stock windows driver.
Overall software experience is as bad as one would expect from Creative. Certainly reason enough for me to avoid using it but let's measure it anyway.
DAC Audio Measurements
Full output was a bit above required 2 volts and caused a lot of distortion. I dialed it down a bit and that produced good results:
Forgot to put in the large graph. It would barely make it into the green bucket of DACs tested so not bad.
Reard channels were not as good:
But still better than many AVRs I have measured.
Dynamic range was quite good relative to 2 volt output:
So distortion is your enemy, not noise.
IMD was also very respectable:
Linearity was also reasonably good:
Jitter showed poor design though with respect to avoiding interference:
Frequency response was flat:
Multitone results were quite poor though:
I have been measuring a bunch of devices lately with this kind of issue. Wanted to make sure it was not the analyzer so I put the Audio Precision APx555 in loopback and this is what I got:
Now this is clean! The Sound Blaster Z is worse by whopping 60 dB in low frequencies!
Headphone Audio Measurements
There is not a whole lot of power available from the headphone output:
This is going to distort heavily at loud levels of listening. Strange that it is powered by PCI-Express yet it has such weak output stage.
Output impedance was high and hence the poor performance with 33 ohm:
ADC Measurements
Could not make the driver work no matter how hard I tried. It kind of worked with Mic but not reliably to measure.
The DAC portion of the Sound Blaster Z is not half bad. But the software and headphone amplifier are best avoided. All in all, It is not a good choice. I suggest buying the Sound BlasterX AE-5 which I just reviewed instead. Yes, it is a bit more money but you only live once.....
Needless to say, I cannot recommend the Sound Blaster Z.
As you see there are no pictures of pink panthers in the review. Reason is that they are on strike. They have many grievances. The top one is that their daily allowance is too low. So please donate money generously using: https://www.audiosciencereview.com/forum/index.php?threads/how-to-support-audio-science-review.8150/
ADC Measurements
