Let me ask permission from the owner.
found this, but have no idea about the internal signal path, forward to the 4 minute mark.@amirm any chance of a teardown? I'm very curious about the internal signal path of this thing.
I replaced an PiCorePlayer/squeezebox endpoint to an Audiolabs MDAC via USB out to a Byrston 3BST with this single box and I have to say while it sonically wasn't an upgrade, it also wasn't a downgrade and it really cleaned up alot of wires and the streaming support was much better since I use Apple Music which I couldn't use on the squeezebox.
I've since got a turntable (Fluance RT85 /w ART DJPREII Phono Pre-Amp) and use the line-in which as this review shows is the weak link in an otherwise decent package. I am wondering if there would be any benefit bypasing the line-in in favour of optical-in via the HDMI to optical adapter (which I believe the Amp shipped with, if not I think I have one from the Beam). I assume, like streaming, this would bypass any ADC on the line-in and go directly to the DAC/DDFA. I have no qualms with the sound as is and am wondering if its even worth the hassle considering my source is a TT which even the noisy Sonos Line-In should handle.
And use the ADC on the ART instead? I don't know. A/D conversion has to happen somewhere along the chain with Sonos.
Sonos does clean up the wiring... except when you want to use it with another amp, then it adds to the cable hell. I use a speaker-level switch and I don't even want to look behind the cabinet.
The ART doesn't do ADC... I would get either a different phono pre-amp that outputs via Optical (so does its own ADC) or put an ADC box between the ART and the Sonos, so the signal going into the Sonos doesn't use the Sonos Line-In as it was measured to be much inferior via Amir's measurements vs a straight digital chain.... The Sonos Amp does have a digital input via HDMI (or toslink via their HDMI adapter).
I guess that was my question, ADC does have to happen somewhere, would it be better to let a better ADC mechanism handle it, bypassing the Sonos Line-In ADC or just use the ADC on the Sonos Line-In despite its bad measurement?
Realistically will any differences even be noticeable given the analog source is a turntable so why go through the additional hassle?
amirn said in the review:
In advanced settings, there is a sensitivity selector from 1 to 6 (?) with 2 being the default for AV components. There are others for itunes, etc.
I was wondering what you had this set at when you tested the line input? The “Source Level” as Sonos referred to in the Sonos app actually has settings from 1 to 10.
The number of Sonos product in my household also quadrupled over the same period.
You've answered your own question on 1.I may have mised it in the large number of posts, but I have two questions:
1 How does one use a Bluray player to play music discs? Of course one can use the disc player with a modern TV and use the TV's HDMI audio output, and that is fine for movies, but what if you want to play a music CD? Is there a way to do this without switching on the TV? Given the Amp's mediocre analogue input I would want to avoid the rca input.
2 What kind of subwoofer filtering is there in the amp (when using a non-Sonos sub)? Is it a combined High Pass and Low Pass crossover where you cannot adjust them separately?
The only trouble I had with it was when listening to dolby digital sources with no sub. I got an absolutely crazy amount of bass. It seemed like a bug to me and maybe if I was using a sub it wouldn’t be an issue. Besides that one issue it is a very nice product in my opinion.I've read through this thread a couple of times and think that this might be the best one box solution for me. I'll be using all digital sources (TV via HDMI ARC and streaming FLAC files from my android phone) and currently use a Qualcomm DDFA based amplifier. This amp should provide much more power and convenience and the sound from digital sources should be unaffected by the line issues.
I have two Sonos Amps.I've read through this thread a couple of times and think that this might be the best one box solution for me. I'll be using all digital sources (TV via HDMI ARC and streaming FLAC files from my android phone) and currently use a Qualcomm DDFA based amplifier. This amp should provide much more power and convenience and the sound from digital sources should be unaffected by the line issues.
Hard to compare the two approaches by price though. Sonos amp you can throw behind or in your TV furniture, plug in HDMI, and you’re ready to go with a single remote or your phone. I just don’t think an RPi plus an amp plus whatever you need to do to make it work seamlessly is the same thing.That amp is waaaay overpriced and we may do better with a Rasberry PI hack plus an audio hat, a PI that may receive a wifi-based stream from a Linux implementation of airplay. Sonos streaming architecture is proprietary and what they have that we would have a hard time implementing are ways to keep all the sinks in sync. Data communication, real-time streaming is what I do for a living and I would like to try doing what Sonos does, but with several Raspberry PIs with amp hats on them, receiving audio streams from a server-PI. PI running Linux, coded in Golang RTC.
I buy my B&W speakers at a shop that also sells Sonos. While there I spend some time listening to their Sonos, blue sound, Dali, etc. Last week I listened to Sonos Beam Gen 2 and Sonos One Gen 2 speakers. They sell really well according to staff and I agree that their active speakers seem very convenient for those who just want to spread out speakers here and there and listen without efforts in connectin them. The sound from those speakers however is boxy and boomy with poor midrange and I can't stand listening to them.
We can do much better,,,,
Are there any differences to the sound signature of the Powernode against the Sonos? I have been considering that too, but the review of the DAC in the Node, which I assume is the same in the Powernode, has put me off along with the significantly higher price.I have two Sonos Amps.
But for another home, I got a 2021 Powernode and I am much happier.
Bluesound has proper Roon support. The Roon experience with Sonos has not been so great for me. I have quite a few Sonos products.
