Review and Measurements of SMSL VMV D1 DAC
helloworld
Hello,Whether the sound(sound color) is standard when you measure PHD.
This is the real data of SMSL VMV D1 measured by our engineers.Could you like to check it again?
Could you like to leave a E-mail for us? Or you can cantact me: [email protected]
Something about the tips to connection of the unbalanced output.Because the output of the VMV D1 is a balanced signal.
I am glad you answerd here. But I guess it's better to invite your engineer to register an account and discuss this product here instead of using the email. Don't bother with the English, I think everyone here can understand.:)
Is there a way to turn off the ASRC in the ESS chip, a.k.a. run it in "sync" mode?
There is a setting for that. What do you want me to test with that?
SMSL-Mandy
That is a very good idea.We will do it.
SMSL-Mandy
Thanks for the review at first.
And can you change the Brand name VMV D1 for us.
This is the connection picture when we measured.Connect the earthing port to ensure the correct data.
Here.
Looking forward to hear from you.Thank you very much.
gvl
SoCal
I came across comments that ESS chips sound different (better?) when run in sync vs. async modes. It might be interesting to see how things are looking on the objective side of things wrt those claims if you have the time. I suspect there may be differences across USB and SPDIF inputs in sync mode, if you must pick one perhaps then USB? And as for what, hmm, jitter maybe and the dashboard view?
derp1n
What effect does the A-weighting filter have here? Surely it's going to roll off the HF noise shown in Amir's graphs rather significantly?
SMSL-Mandy
A-weighting filter is a filter in the test instrument that conforms to the hearing habits of the human ear.
gvl
SoCal
This filtering isn't really meant for DAC measurements as far as I understand.
gvl
SoCal
Yes, look at the lower right corner of the graph, it shows 96000Hz, means 192k sample rate.
Why? Look at the synchronization frame rate, it was 192kHz in the original A-weighted graph, now it's down to 48.
gvl
SoCal
I've just realized Amir did say the HF spikes were present at lower sampling rates as well, so I suppose the 48kHz results above are of interest too.
