As I implied above, there is talk on the head-fi Yggdrasil thread that even a 30 minute warm up helps the sound of this DAC. So I set out to test that theory by shutting down the Yggdrasil after two weeks of running and let it come down to room temp.
I then powered it up and ran it for a little over an hour while take a measurement of THD+N every second. THD+N encompasses any noise from the product and its non-linearities/transfer function. Any change in behavior of the device would change THD+N.
To speed up the temp change and aggravate the situation more, I even applied generous amount of heat to the enclosure on all surfaces starting around 7:00 minutes. The top was so hot I could barely hold my hand over it. An IR scan of the top of the unit showed this:
Due to reflectivity index of the case, it is under-reporting the temperature. It was quite a bit hotter but still, you get the idea.
Here are the results:
Yup. Nothing happened. The little ups and downs are naturally occuring and are due to variations in both the DAC and measurement system.
BTW, the above is at -20 dB signal so don't compare it to my previous measurements (THD+N gets worse with smaller signals).
Here is the other thing: if there were going to be an effect, it would require a DAC with a far better measured performance to matter. The Schiit Yggdrasil has some 30 dB higher noise and distortion than other state-of-the-art DACs. Its distortion and noise would swamp any variability in temperatures.
And oh, electronic noise goes up proportional with temperature. So the notion that "warming up" is good for these things, is exactly the opposite of what you want. The best DAC in the world would be one frozen in space! Look up thermal noise:
https://en.wikipedia.org/wiki/Johnson–Nyquist_noise
Summary
We have done long term testing that showed nothing from linearity to SINAD and distortion products changes in any material way. See this post:
https://www.audiosciencereview.com/...ts-of-schiit-yggdrasil-v2-dac.3607/post-86400
In this post, I have shown effects of short-term warm-up which is nil.
No way, no how this device changes its sound in the short-term, or long term.
