Do you use particular headphones?I heard so many bad stories about MB internal audio processing so I thought I might just try external.. My amp doesn’t have balanced inputs, so Im limited to RCA only..
Thank you very much!First, does your Onkyo has XLR input? If not, I see no reason to buy a SU8V2.
For less, and a bit more than the Modi 3, I would go for the DX3 Pro. More digital inputs (including Bluetooth Aptx-HD) and a decent headphone amp.
If you are limited to 100$ and don't need and headphone amp, then the Modi 3 is a good option.
A headphone DAC means a DAC with integrated headphone amp.
I dont use headphones, only amp to speakersDo you use particular headphones?
OK. Then, the DX3 Pro is pointless. Modi 3 is a great option.I
The modi does not support hardware decoding of MQA. It can only do software decoded/'unfolded' MQA (i.e. through Roon). This is information you easily find by doing a little more research..Thank you very much!
As I dont use headphones, I probably will stick with Shiit modi 3!
In test Amir mentioned about the Usb problem , and a potential solution by using Wasapi...I dunno the guyis this a driver? Can I select it in AudioNirvana? Will the Modi be a friend with MQAs from tidal?
Cheers)
You can stream "unative" MQA from both Roon and Audirvana. It will be concerted to regular FLAC 24b.Thank you very much!
Cheers)
Interested to know what you've heard? There's certainly nothing wrong with the audio output from most macbooks.
Sure but I doubt these can provide the same amount of performance as a good external DAC.They might not have enough juice for driving inefficient high impedance headphones, but I can't imagine what's wrong with them as a line out to an AV receiver.
Hi, I’m very new here and firstly want to say you thank you for such an amazing tech forum.
I do have a question though:
I run Onkyo amp(no dac) with QAcoustics speakers, and normally I stream music from my MBpro 2017 via 3.5mm output..(Tidal)
Would it be ok to use Shiit modi 3 as Dac in my system or should I look at other dacs ? I also read your reviews about Smsl su8v2 .. can I use USB with bith of them? Also I was a bit confused with “headphone dac” definition..
Please help me to choose
Thank you
oh yes DDD I runOnkyo 9010 with QAcoustics 3050i and I hope my room is not too bad for themI would suspect that the amplifier's and speakers' distortion, plus the room, make a much larger difference than the DAC.
The V90 is a good dac (see: https://www.audiosciencereview.com/...easurements-of-musical-fidelity-v90-dac.3787/) but is hard to justify its higher cost. So yes, you can get the Modi 3 and get similar performance.
No. Not with any of them that I test and give high marks without one.BTW do you think the Modi 3 (or DACs in general) may benefit from a linear power supply?
As to other options, you can go cheaper with Topping D10 at $70 and get a much nicer looking DAC with display, bridge to S/PDIF, etc.
The D50 is nice but you are paying for the display and remote. If these are valuable to you then, it is a better option.
SMSL SU-8 version 2 is also nice at around $250 with balanced output.
Correct. Without ASIO4ALL support I can't repeat all of my measurements but I think USB is fine.So after the ASIO4ALL issue is resolved, I assume the USB measurements are very close to SPDIF?
