- Thread Starter
- #181
"Fun" little observation and measurement. After fixing the grounding issue I thought I tap on the top of the box to makes sure it still maintains connection. I was surprised to see a significant rise in noise in the FFT:
Investigating further, I realized it is the volume control that is "microphonic" and generates noise due to vibration. Because the lid is tightly coupled to the pot shaft, it transmits (and probably amplifies) the vibrations. The pot should really be isolated from the case this way.
I tested the same thing on iFi iDSD and unless you bang on the volume control itself or just at the edge of the case, there is no such effect.
I say this because I am selling a new tweak for Schiit Jotunheim that is called the "Schiit Isolator." As with the jumper cable, it is made in a tropical island and costs $300 for each footer. You will need four for best performance and for that, I provided a $100 discount for a total of $1,100.
