maxxevv
- Joined
- Apr 12, 2018
- Messages
- 1,872
- Likes
- 1,964
By the way, since you are a Shure SE215 user too, do you know of a substitute regular cable (not balanced) in case that i break mine? The original Shure is way to expensive and i am sure in Amazon or AliExpress there might be good choices as well. The thing is knowing some reliable vendor who sells a good quality cable at a good price.
https://www.aliexpress.com/item/32916162030.html
The link I put previously also has 3.5mm jack with straight MMCX connectors. Pretty affordable and well measuring cables, though some may find them a little on the thick side of things.
