So using the SINAD chart, if one chooses 2 DAC’s from the same tier, there is no way anyone could hear any difference between the two in a blind test? What about a tier 1 and a tier 2 DAC or a tier 1 and a tier 3? At what point does the sound of a DAC become distinguishable from another?
If we are saying that all tier 1 DAC’s will sound identical, then we should simply be choosing one on build quality (so it lasts), aesthetics and features we need?
So assuming all tier 1 DAC’s do sound indistinguishable, will there every be a time when a DAC will reach another level that it will sound better than any of the tier one DACs? Say when it reaches true 24 bit as opposed to the 20 bit we seem to have peaked at?
Thanks
You've boiled it down perfectly.
When you look at this chart:
You can see just how small these signals are... When someone claims they can hear the 'obvious' difference between -90db and -100db, they are saying they could hear the difference between a 0db reference signal from 20 to 80 MILES away.
I don't believe I could tell a difference... I don't believe anyone can.
So, yes...pick based on features, design, inputs and outputs, whatever you like...but to pick one believing it will sound better, assuming it is at least competently designed, isn't 'sound' thinking...
Once you've got transparency...you've got transparency...no more stress needed.
Time to focus on speakers and room treatment for better sound...not solid state electronics, or cables, or quantum iisolators..
