Toslink. It even hums when the DAC is turned off. Ugh...
Can you also do a polarity check on your outlet?
How exactly do I do these things?Ground loop? Have you isolated it?
Ah, that is why this did not mean anything to me. I live in Europe and we can turn all our plug by 180 degrees. There is no real concept of left-ground, right-hot here. That being said, turning the plug 180 degrees did not do anything.
Edit: I just checked which one of the contacts here is hot and ground. Turns out both are hot. The "ground" contact is just less hot than the other one. This is a really old building with old electrical installations. All the outlets are 2 pole instead of 3 pole.
Oh, I see. I unplugged every device in this room except for the DAC, but no change.I simply meant to isolate the device on your electrical system, by unplugging anything else that may be sharing a common ground. That way you could see if it was being caused by a ground loop.
That may well be your problem then!Ah, that is why this did not mean anything to me. I live in Europe and we can turn all our plug by 180 degrees. There is no real concept of left-ground, right-hot here. That being said, turning the plug 180 degrees did not do anything.
Thanks! Seeing this graph led me to understand how to set the e.q. for my headphones. Found the frequency response graph for my headphones and then it all clicked.Well I just connected it to my PC via USB and that made the hum go away. I think I will just leave it at that and hope my next apartment has better electrical installations...
Really enjoying this device now. The low crosstalk even with the Andromeda IEMs is amazing. There just isn't any. Many people prefer the Andromeda with an output impedance of 2 Ohm and so do I. An impedance adapter would introduce crosstalk, but the change in frequency response can be easily achieved with PEQ on the ADI2-DAC. The PEQ is a real game changer. Here is a quick setup I did for my HD800:
I was skeptical about only having 5 bands, but I even had one left to correct for the ear pad resonance around 50 Hz. And the bass and treble controls act like a configurable shelve filter, so effectively it can be up to 7 bands for you to use! This is so much better than buying an amp that has the "right" amount of treble rolloff and won't work with any other headphones.
Yup, the ADI-2 DAC only came out as an FS version. The Pro's been around for a while longer, and only got an FS update recently. The Pro in the comparison is a non-FS model, which is why I'm curious as to what a newer FS one would do there. Good to have the comparison, though -- I'm surprised at the difference there, looks like a decent upgrade from a specs point of view.
A single AKM 4490.
