Review and Measurements of Purifi 1ET400A Amplifier
If possible, please overlay IMD and THD per frequency with nc400.
I don't have a good IMD measurement for Hypex NC400. At that time, I was testing *input* level to the amp versus IMD which is not good because different amps have different gains. With that important caveat, here it is:
Purifi 1ET400A Class-d Amplifier Module IMD distortion compared to Hypex NC400 Audio Measureme...png
And here is the THD+N versus level versus input level for Hypex NC400 relative to Purifi 1ET400A:
Purifi 1ET400A Class-d Amplifier Module THD vs Frequency and Power vs Hypex NC400 Audio Measur...png
We definitely have a cleaner amplifier here, as good as the NC400 was.
rajapruk
Do you test output impedance?
What is difference here to nc400 and AHB2?
tktran303
So the first 14dB of amplification was perfect in the nCore400.
In this refined product Bruno perfected the final 8dB of amplication.
Bravo
The X axis is what, watts?
It is except that the Purifi was run with two channels running, the AHB2 was with one (compensated in the formula that computes efficiency).
Here is the output impedance versus frequency. Note that the scale is in milliohm (1/1000 of an ohm):
The spec is 65 micro-ohm at 1 kHz (0.065 milliohm). Likely they measure right at amplifier terminals. Mine are through the case wiring, and into my 3 to 4 feet of wire, connectors, etc. So the amp basically has zero impedance and what is seen is the wiring impedance. No rise with frequency which is very good for a class-d amp.
Soniclife
Excellent, I was hoping it was very good and nothing for anyone to ever worry about, it's rather better than that.
If these are sensibly priced they are going to be in a lot in amps very soon, so it's good to get as comprehensive a set of measurements as possible.
Massimo
Looking forward to seeing how any of the NC1200 based amps stack up. Hopefully we’ll see one on the test bench soon.
tktran303
I really don’t understand why you bother comparing CMRR or PSRR.
The data is clear to see that new module is better than the old.
The designer of both is the Bruno Putzeys.
