Review and Measurements of Purifi 1ET400A Amplifier
Thomas savage
The Watchman
uk, taunton
Does adding the 2nd power supply improve the measured results? You should send an amp to Amir with 2 supply’s, along with the harness to connect a single supply. So we can all see if adding the 2nd supply is worth the additional money.
Ah Mike ... Again ?! Really ...
rodtor
Toronto
FYI I'm about to order an Audiophonics HPA-S400ET with OPA1612 instead of OP275. They said no problem, easy to work with and quick follow-up.
This is interesting, @TomJ. I am also interested in this amp. What are the advantages of the OP1612 over the OP275, and what is the additional cost?
mocenigo
Advantage: better measurements.
Disadvantage: the OPA 1612 has some phase rotations that could cause oscillations when feedback is used. The LME49720 is better from this point of view. In fact, I would say that it is better because of this. So you can use more feedback on the LME49720 and keep better linearity, lower noise THD and IMD in the final circuit considered as a whole and at the same time be sure it is more stable as well.
Roberto
TomJ
Palo Alto CA
Thank you Roberto, very helpful. FYI Audiophonics changed their standard build spec yesterday from OP275 to LM4562. Any thoughts? What would be your top op amp choice(s) for a Purifi buffer?
mocenigo
I would be tempted to follow NwAvGuy and say that all proper opamps when used properly are all equally good and sonically indistinguishable. But there are caveats.
Opa1612 and LM4562/LME49720 are both good. If you want discrete, then Sonic Imagery 994 or the Weiss op amps. The sparkos opamps are very good as well but are IMO sonically warmer than the Sonic Imagery. I ended up not linking that at all. Never heard a Weiss.
hence, once you have a LM4562/LME49720 or a OPA1612 I would not worry, the circuit around is what makes a bigger difference.
Roberto
TomJ
Palo Alto CA
Since my post they replaced the OP275 with the LM4562 in their build spec and I've ordered that. To your question, the price would have been the same with the OPA1612.
Vincentponcet
How to compare different brands of purifi amps sound quality wise ?
It is all about the buffer as they use the same amp board and the same power supply.
Looks like the current bargains are audiophonics and Nord
Any reviews of the audiophonics buffer ?
SIY
Alfred, NY
Unless someone really screwed something up, they'll sound alike as long as you match levels and don't peek.
Billy Budapest
Both of those use boutique discrete op amps which although have negligible (or zero) impact on sound quality, would adversely affect the measurements. I’d look at March Audio for an implementation with standard opamps.
mocenigo
Audiophonics is using a LM4562 opamp and Nord has a "bargain" option with OPA1612 opamps. They are not boutique, they are solid, well established IC opamps. Please double check your facts and avoid spreading false information.
TomJ
Palo Alto CA
It gets complicated... If you find a review, it could be for an OP275 buffer (they changed the build spec to LM4562 just 2 days ago). Or some other op amp, because their IC socket supports op amp rolling and you can order it with a different op amp if you prefer. Another variable might be the buffer gain which you can reset with jumpers.
Vincentponcet
The op amp used is one thing, but the buffer board itself is also a thing to consider. It has voltage regulators, and caps. The schema and the components could be good or bad.
Btw audiophonics is using a single stage lm317 / 337 voltage regulator. Does not sound that much high end. Any information on Nord revC buffer board ?
https://www.audiophonics.fr/en/prea...odule-buffer-stereo-aop-op275-v22-p-4227.html
March Audio
Albany Western Australia
The best "boutique" op amps perform about the same as the quality op amps from the likes of Texas Instruments. However certainly not better and cost significantly more, 10 or 20x. Some of these boutique parts perform significantly worse.
There is just no technical logic to implement them, but they do appeal to audiophiles and they can be charged more for the privilege.
Now, the op amp is one thing but there is a lot more to the final performance of the buffer. Board layout has an impact. Different caps and resistors have different distortion characteristics. Regulators need to be suitable for rejecting the smps high frequency noise. Standard regs are poor in this respect.
So just because a board contains "op amp X" does not mean it has good technical performance or sounds better.
TomJ
Palo Alto CA
Billy Budapest
Chill out, dude! I’ve looked at the configurations on their websites and have seen the boutique discrete opamps. It is certainly not “false information” and I am not “spreading” anything. For sure regarding the Nord. As for the Audiophonics, I had remembered seeing an implementation where they used discrete opamps. Maybe their design has changed since then. In any event, I find the entire discrete opamp industry rather silly.
Vincentponcet
I was talking of the cheapest purifi amps, around 1500 euros for stereo amp. Those are not using boutique opamp.
Nord uses opa1612a with their RevC buffer board
https://www.nordacoustics.co.uk/product-page/nord-three-1et400a-stereo-amplifier-1
Audiophonics uses lm4562
https://www.audiophonics.fr/fr/ampl...ereo-class-d-purifi-2x400w-4-ohm-p-14393.html
mocenigo
Yes, audiophonics explicitly states you can use your own discrete op amps (but they sell you only the IC ones) and Nord has models with discrete ones for sale — but you were referring to the bargains. And the “budget” model from nord has the version C of their boards with a socketed IC opamp.
the nord models with boutique discrete opamps are no bargains wrt the other offerings by competition (Apollon, Rouge, etc)
Billy Budapest
“But you were referring to the bargains.” That’s an incorrect assumption.
