Review and Measurements of Paradigm PW-Link Streamer/DAC
I'm a little confused by your question: What are you using as your music source? If the Wiim is after the PW Link, then it isn't getting 'corrected', unless I'm missing what you're going for.
How is this connected, all digitally?
Pw link - toslink to wiim streamer coaxial to DAC.
Streaming via PW link. I want to have my sub corrected by ARC connected to my wiim.
I always thought the DAC was terrible hence the external DAC. The arc is why I put the PW link in the chain. I really need arc in my condo listening room.
Any software solution to the room correction, or what would you recommend for this task?
The WiiM itself has room correction and manual PEQ controls, so room correction can be accomplished .
Either by running its room fit software or by taking measurements yourself and manually adjusting the PEQ .
Thank you very much. I will try with the Wiim by itself, and see if I can dial the room correction in. The graphs from Anthem Arc will give me a head start.
