I believe holding down the mute button for a few seconds turns off ARC on the PW Amp.......Or perhaps this simply flattens the ARC curve and the DSP is still engaged.
I did not know that. I see the manual says: "To switch off ARC™ settings: PRESS and HOLD for 5 seconds. Upon releasing the button, a “negative tone” will sound verifying ARC™ settings are switched off." I am pretty sure this means it simply flattens the EQ settings rather than cuts it out of the circuit.
ADD: I just tested this: When you hold the Mute button for 5 seconds it makes a kind of sad "negative tone" I had not heard before. But, with the amp turned up quite high and no music playing, I do not hear a difference in the soft hiss with it off or turned on again. So I think ARC is still in the circuit, and the mute button 5 second hold is a way to compare the original flat frequency response to the ARC corrected one.
The test here of the MiniDSP HD 2x4 ($280 with mic) seems to test better than the PW/Amp. But the measurement used an older reporting method and few of the charts show the analog input to directly compare. I have not used a MiniDSP, but I understand the MiniDSP HD 2x4 provides measurements but does not automatically perform analysis or make changes. I believe you make them manually. I understand that the MiniDSP HD Dirac ($480 including mic) has the automated correction functions. I have not seen any in depth comparison of Dirac and Arc and if anyone knows how they differ I would be interested.
