First, thanks to Amir for measuring this. As a
happy owner of the PW/Amp I have conflicted feelings about the results.
Measured as a power amp, I am pretty sure that Amir's testing was fair and accurate. In fact, the few published mfg specs of the PW/Amp (and Identical Martin Logan Forte) are largely in alignment.
Compared to recently tested power amps...the results are mediocre...significantly better than a few, significantly worse than others...but they seem in alignment with Paradigms published specs and assumed design goals. That is, Paradigm must have felt that this kind of performance would not result in noticeable distortion for the intended audience. Mine sounds just fine to me. I have not done objective blind listening tests with ARC turned off.
So why am I satisfied with mediocrity? Lets focus on the PW/Amp rather than my worldview
The PW/Amp (and PW/Link I also own) have had a greater positive impact on my two audio systems sound than any components I have changed, besides upgrading speakers. My experience corroborates Amir's statement that
"No doubt room EQ will make a bigger difference than any of these measurements do in the sound of the amplifier". In one of my setups the impact of ARC is large, in the other, a very difficult desktop setup, it is phenomenal.
The monitors have dip switches to adjust HF/MF/LF and Low Pass...and the red lines are the best I could do with careful listening. The Green is the Corrected ARC response. The change is not subtle. In fact, my wife, who was vaccumming upstairs suddenly...never mind
So while I am pleased that Amir took the time to measure the PW/amp and believe his testing was accurate; I am also convinced that what you measure is equally important, and the real benefit of this kind of device on sound quality was referenced, but not measured.
