Review and Measurements of Okto DAC8 8Ch DAC & Amp
josh358
Mine won't be here until Friday, but the prototype didn't have any of those issues, at least as I had it set up.
wineds
Melbourne, Australia
You should probably look into installing some proper protection circuitry. I have unobtainium beryllium domes.
You can install:
1) large high quality contact relays driven by a delay circuit to let all the upstream electronics settle down (I have considered this but never done it)
2) Install capacitors correctly sized between the amp out put and the voice coils. The correct size is large enough to pass signal to below the crossover frequency and small enough to not pass enough charge to explode the voice coil
3) Install fuses again small enough so that the voice coil does not protect the fuse. Both fuses and capacitors are probably best installed on both legs of the driver connections .
In my case I installed fuses at one quarter amp slow blow. I had a pack of half amp, at the ready, because I expected the quarters to blow but they never have.
These will also protect against an output transistor failing and putting a power supply rail voltage on your spensive driver voice coil. None of this would likely be audible.
I have noticed a very slight pop at turn on/off but it is very minimal and I am not at all concerned about it. My amplifier is not balanced though so in this case there is no guarantee to be pop free.
BTW no way would I be using slow blow fuses if I were you! In the case of a fault you want fuses to blow quickly!
gene_stl
St.Louis , Missouri , U.S.A.
1/4 amp slow blow is so they don't blow on music (which they never have) if you do the arithmetic it doesn't take much wattage continuously to blow them. Since they are on tweeters and upper midranges they don't get that much energy at normal and even loud listening levels. But I wouldn't argue much about putting in regular fast blows. I was more concerned with them being too small and bought 1/2 amp pack at the same time. Never needed them. And it's not that I never turned it up.
Snafu
If You turn You devices on off in correct order, there shouldn't be any pops etc
in my case:
ON:
source : dac : preamp : power amps
OFF:
power amps : preamp : dac : source
and agree about quick fuse, if something is going wrong let the fuses blow :eek:
rajapruk
Others using balanced connection, please chime in. Is there a significant pop?
Snafu
right... isn't that always the easiest solution for... everything:
"don't buy or do anything that may cause any harm or problems"...
:rolleyes:
rajapruk
:rolleyes:
That is why @pos never did start a big, hopeless, and utterly complicated DIY-speaker project. He always chooses the easiest solution for everything!
Or do I remember wrongly? ;)
pos
:rolleyes:
In that particular situation I feel like it is a reasonable approach, and easy enough a path to follow with current offering.
For example I am using a pair of cheap SMSL M8 that do not emit any kind of noise in any situation I have faced so far (start, stop, clock sync, bad spdif, etc.), and same goes for the THX789 amps that feed my compression drivers. The nc400 does emit a faint DC-related noise on start/stop, but it is connected to the woofers.
The rest of the chain is digital, and reliable enough in that regard too.
Snafu
^^ It is, and i agree.
But when buying products you don't 100% know how well they work together.
Feyire
Netherlands
Any further owners like to chime in on the listening experience?
Reactions: g29
g29
My Okto Dac8 arrived this evening (order #63) looking forward to setting it up tomorrow.
It appears the orders are not being shipped out in chronological order for some reason.
Neddy
Wisconsin
Not that unusual - could be color choice or accessory selection availability.
At least the shipped order #s are an increasing series, even if not monotonico_O
Neddy
Wisconsin
Me neither...but your series approaches the limit of... Xmas Day!! Sweet.
YAY!:rolleyes:
Verausci
I've been doing some searching and reading on the DAC8 Pro and I understand that the DAC8 Pro DSP version was discontinued due to an inability to procure more miniSHARC units? It appears however that the miniSHARC is now available from the miniDSP website.
I wonder therefore if more DAC8 Pro DSP units will be produced if the miniSHARCs are now available again?
