No news for the firmware update tool?No news of the firmware update tool?
Still waiting on that. There’s been no update from Pavel as far as I’m awareNo news for the firmware update tool?
Put my order in one January 7th. Would hate to think I threw $1400 down a rathole. I'm sure everything is Ok. I hope.I have ordered stereo on 24th Dec. Had a auto reply with order number. I’m sure after holidays, they will update with progress. I know, Its going to be a long wait..
Pavel should visit the forum more often, since there are quite a few buyers, including myself, resident here.Heard back from Pavel personally, so all is well and order is on track. So everyone can breath easier. This is quite apparently a going concern, and I have high confidence they will be fulfilling my order.
With 3way speakers, can I assume you have only 2 and, therefore, want 6 outputs? Can I assume that you are using only stereo sources to your 2 3way speakers?Last week I bought a license for Audiolense. I managed to get a good measurement of my 3-way speakers and generated a config. file. So far nothing wrong, but now I am unable to make the dacpro8 play more than channel 1 and 2. JRiver is my audio player. Bernt, the creator of Audiolense could not help me with this, so I try it here. Hopefully someone here can help me with the correct settings in JRiver and Windows.
You are getting only L/R because outputting 5.1 simply puts stereo into a 5.1 package but doesn't put anything into the other channels. You have to supply them with signal. To do so, you go to DSP Studio and select Parametric Equalizer. Then you can copy the L signal to two other channels (LTweeter and LWoofer, for example) and copy the R signal to two other channels (RTweeter and RWoofer, for example). Then you will have 6 real channels and can apply the suitable convolutions to each of them.Thank you for your response, Kal.
I get it up to point 1.
From point 2 on, I don't see how to do that. Maybe you can clarify this for me?
As far as I understand it now; the crossovers, channel routing, gain, correction, etc. are present in the Audiolense config. file. When I play music, I see the convolver is working and converting the signal to 6 channels. (see screenshot)
Only the bass and woofer (channels 1 and 2 of Okto8pro) of the left speaker work as they should, otherwise all speakers are silent, except for the noise of course.
I am using the driver from DIYINHK, but ASIO4ALL, wasapi etc don't work either.
So if you can explain how to do this:
2. You need to copy the L input to 2 additional channels and the R input to 2 additional channels.
5. At this point, you probably can insert the suitable convolutions into the appropriate channels.
I am very grateful to you.
Things will be clearer after some sleep.It's a little late in here, but I think I understand now. First sleep, because tomorrow I have to work. Thank you very much in advance.
