mdsimon2
BTW, I am just searching/learning about the rather old-fashion sync mechanism of S/PDIF and AES/EBU.
I hope your web browser would properly translate this web article into English or your language.
We can easily understand that "sync mechanism of S/PDIF and AES/EBU" has already become really outdated in comparison with present "SOTA" Dante and/or Ravenna on so-common-now GigaBit ethernet LAN protocols. The "inter-sync" implementation between home-use affordable digital audio gears, therefore, looks far behind the already available and affordable SOTA technologies, I believe.
In any way, I would be really happy if DAC8PRO "MkII(?)" would have nice master oscillator clocking (10 MHz?) block in it and would have master-clock out/in BNC design so that the second slave DAC8PRO "MkII" can bepreciselycompletely in-sync with the master one; then of course PC-DSP should be able to recognize, by USB-ASIO driver, the total of 16-Ch or 14-Ch for DSP-based multichannel audio processing.
From technical point of view (not from market size and profitability), it is now very easy to implement such "clocking I/O block" in DAC gears since e.g. TEAC CG-10M-A High-Precision Master Clock Generator ( 4-BNC outputs of 10 MHz master clock) is available and affordable around USD 1,000.
I do hope Pavel of OKTO is still keeping his eyes on this thread.
They have already stated they are against a word clock input:
Q: Why doesn't the dac8 PRO have a word clock input?
A: When processing AES/EBU inputs, the clock is encoded with the signal. This means that even if multiple DACs are used, they will always operate synchronously with the source device. Additionally, the clock recovered by the dac8 PRO from the AES/EBU stream has lower jitter compared to the word clock received from a standalone unit, which is then internally multiplied upon reception to match the frequency used by the DAC chip. You can find online measurements comparing these two methods using competitor DACs. These comparisons typically show superior analog performance using the clock recovered from AES/EBU signal.
The other thing that goes unsaid in the FAQ is that although the XMOS uses the AES recovered clock, the DAC chip itself always uses a local oscillator as described here -> https://www.audiosciencereview.com/...nts-of-okto-dac8-8ch-dac-amp.7064/post-333521.
I don't see how SPDIF/AES are "far behind" Dante/Ravenna, other than that they require physical cables. Seems to me like you are searching for a solution to a problem that does not exist.
The biggest unknown in all of this is how connecting two Oktos to a single PC will behave. Can they use the same driver? Do they need to use different drivers? Even if they are clocked the same does the PC data start at the same time or is one DAC offset from the other? Pavel described these issues in a reply to you three years ago -> https://www.audiosciencereview.com/...nts-of-okto-dac8-8ch-dac-amp.7064/post-450024.
Michael
