I got these recently. They do the job. Well built and I like that the connection feels firm, but doesn't have a death grip, unlike some I've tried.Just saw these semi-rigid cables on the JDS Labs site. I'm considering ordering a pair since my Atom likes to stand on its hind 2 legs with my current cables...
https://jdslabs.com/product/stack-rca-cables/
PS guys from JDS Blog comments, a new DAC design from JDS is coming late 2019 as well as a more premium Atom, think EL Amp with matching specs.
I believe more 'premium' only in the enclosure, knub, overall luxurious feel. I think they have Atom already perfected elsewhereAhh, don’t tell me my ASR special will already be out of date!
where did you get this ASR special? Do you have a link good sir?Alright guys. I pulled the trigger and have the ASR special. I compared subjectivity the Atom to my Burson Fun. I don’t have any professional equipment to measure them so take it with a grain of salt. Barely noticeable but the soundstage is slightly bigger when using the Atom. On the other hand bass is, again, barely noticeable but tighter and more controlled on Burson Fun. We are talking about silent room void of outside noise. Mids and highs are equally good. Burson did very good job by removing noise but the atom is something else. I was shocked how black is the background. It is unbelievable. My sensitive IEMs sound better with the Atom, same for my very low impedance Verum 1 planar magnetic phones (I am not trying to say they sound bad on the Burson Fun, it’s just that the JDS labs Atom did a better job here) Everything else is great on both. The low gain stage is very well implemented, I am very impressed. On a $99 device, are you kidding me?!! As a preamp to my Adam Audio speakers I have to give it to Burson, it sounds marginally better to my ears. But did you notice the words I am using such as ‘barely’ and ‘marginally’. I am comparing $300 amp (actually more expensive because I purchased different op-amps) vs $ 99. The Atom is just phenomenal. The built quality is very good, I don’t mind the plastic. But the volume knob is no go. I like the diameter actually but not how shallow it is. I found an aluminum volume knob with a 23.5 mm diameter. Do you know the diameter measurements of the original volume knob?
Oh, when I saw your first comment I thought you meant the specs (like power output) would match the EL Amp, since I think the EL has a bit more, right?I believe more 'premium' only in the enclosure, knub, overall luxurious feel. I think they have Atom already perfected elsewhere
So it'll just be the design then; that's still good as that's one of the main reasons I was still on the fence about getting one, otherwise I'd probably have ordered an Atom already. =)
Which opamps did you use with Fun? I have both amps and as for now I would say that Fun has a bit wider soundstage compared to Atom.Alright guys. I pulled the trigger and have the ASR special. I compared subjectivity the Atom to my Burson Fun. I don’t have any professional equipment to measure them so take it with a grain of salt. Barely noticeable but the soundstage is slightly bigger when using the Atom. On the other hand bass is, again, barely noticeable but tighter and more controlled on Burson Fun. We are talking about silent room void of outside noise. Mids and highs are equally good. Burson did very good job by removing noise but the atom is something else. I was shocked how black is the background. It is unbelievable. My sensitive IEMs sound better with the Atom, same for my very low impedance Verum 1 planar magnetic phones (I am not trying to say they sound bad on the Burson Fun, it’s just that the JDS labs Atom did a better job here) Everything else is great on both. The low gain stage is very well implemented, I am very impressed. On a $99 device, are you kidding me?!! As a preamp to my Adam Audio speakers I have to give it to Burson, it sounds marginally better to my ears. But did you notice the words I am using such as ‘barely’ and ‘marginally’. I am comparing $300 amp (actually more expensive because I purchased different op-amps) vs $ 99. The Atom is just phenomenal. The built quality is very good, I don’t mind the plastic. But the volume knob is no go. I like the diameter actually but not how shallow it is. I found an aluminum volume knob with a 23.5 mm diameter. Do you know the diameter measurements of the original volume knob?
I use Sparkos singles. I also have the V6 vivids but they are collecting dust somewhereWhich opamps did you use with Fun? I have both amps and as for now I would say that Fun has a bit wider soundstage compared to Atom.
I happen to own both of them as well.I use Sparkos singles. I also have the V6 vivids but they are collecting dust somewhere
Good day everyone
Have any of you used Atom with a hard-to-drive planar headphones? Such as HE-560 or HE-500 or maybe some TOTL LCDs
What was the result? Was atom able to drive them beautifully?
Tried it with the Audeze LCD-3f, LCD-2f, and EL-8, HiFiMan HE560 and HE5se, all sounded good to me, Had enough power to make it to an uncomfortable level with room to spare on the knob.Good day everyone
via balanced to unbalanced plug in adaptor
