- Joined
- Jan 20, 2025
- Messages
- 45
- Likes
- 52
I’m pretty sure it doesn’t. Transformer and unregulated linear PS. Regulated for opamps. I think there is a VCA between the input/HP Filter and the LM3886 for the compressor. You can jump over to the rane site and see the schematic in the pdf tab. I’m sure that is one reason the Modulus-86 costs more. Engineered circuit to get the most out of the chip. Rane’s amp was for background amplification like a restaurant. But certianly could be used as a home amp to drive easy load speakers.Does the Rane MA3 have error correction? That's the central point of the Modulus amps. The error correction drives the distortion into the abyss. That's why the Modulus-86, -286, and -686 sound much better than other LM3886-based amps.
Tom
Not sure if it okay to post urls. This is important to the differentiation between the Modulus-86 and the Rane MA3 that both use the LM3886 monolithic chip.
MA3 Multichannel Amplifier
The MA3 is a 3-channel amplifier designed to operate reliably in commercial environments, for use in paging, foreground and background music distribution.
www.ranecommercial.com
