Ah, ok. I measured that IRL just now;
Yeah. It's about the size of a hardcover book.
Like the power and XLR connectors look huge so it made me think the whole thing was smaller, maybe my eyes are playing tricks on me or something.
IEC C14 power connectors are monstrous. The one I plan to use in the HPA-1 is the smallest I could find and it's still 33 mm wide! The XLRs probably look huge because the model from Neutrik isn't all that detailed. There's a plastic overhang at the top of the connector that extends pretty far back. That's probably the dimension they used for the model. That said, there is no empty space on the rear panel. The connectors are packed about as tight as possible. I left the most room between the IEC inlet and the XLRs. There're some metal bits in the bottom of the chassis that I need to stay away from (1/4"/6.3 mm clearance needed for electrical safety!). That severely constrains the connector placement.
I did consider going with the IEC C2 (shaver plug) as the Mean Well supplies I will use are Class II medical switchers, thus feature their own isolation between primary and secondary, but I don't like the idea of having mains voltage inside a non-grounded metal chassis. I could have used the IEC C6 (Mickey Mouse plug), but that's starting to get large and people wouldn't have the opportunity to geek out over power cords without using an adapter. So IEC C14 it became.
I definitely wanted a compact high-performance amp. As we've discussed before, I'm aiming for the $500-600 price point. That's remarkably hard to hit if you want a high-performance product that's safe to use, enclosed in a pretty box, has a large volume knob that feels right, etc. that is manufactured at western wages. One of the knobs I can turn is the size of the box. Large box -> higher cost. So minimize the size of the box. Reducing the feature set is another knob. So two gain settings instead of three (saves a $6-7 relay plus a few other sundry items and the cost of their assembly and test).
Another knob I could have turned to reduce price would be the performance knob. Lower performance -> lower cost. I left the performance knob cranked to 11. Okay... Maybe 10.5. But still... I know I charge more than the eBay vendors. I have to. I like to eat periodically! Thus, my products
have to be better.
I should have a handle on the cost within the next few days. That'll allow me to figure out what the amp should cost. At the very least I think I can do something like $549 for the early birds who are willing to preorder (and wait for stock to arrive). Once I have amps in stock, the price will go up. I'm not planning to have any sales after that. I've arrived at the
same conclusion as Schiit regarding sales: They suck for everybody and result in higher prices.
Tom
