D
Deleted member 11516
Guest
Great, and when can we expect this anticipated review?Looks nice. All other details will be in the published review.
I'm guessing the October issue which hits the street inGreat, and when can we expect this anticipated review?
Latin, they don't understand plain English. LOLVide supra.
Here’s what I found out about the M28
8 channels of amplification (M27 is 7), $5,500 (converting euro’s to dollars)
https://www.hi-fi.ru/news/dom/detail/nad-m28-teper-vosem-kanal/
The source is a French website on-mag.frGiven the model number I figured it must be 8 channels. Heck, I only need 5. May need to look elsewhere for my amplification. Thanks for the info.
https://www.on-mag.fr/index.php/vid...-amplificateur-8-canaux-dans-la-serie-masters
The picture shows MSRP 4,250GBP/4,999$/4,999EUR
Yes 8 channels. Which makes a price similar to NAD M27
Even for a 5 channels, it is an acceptable price for a brand model. Current Purifi 2 channels amps are at about 2k$.
The article speculates the possibility of a three channels amp to have a 11 channels set up for atmos.
Nad M28 is listed on NAD websiteA UK store prelisted it at 3,995 GBP and available in July
That would be a great news.
https://www.audiologica.co.uk/product/nad-m28/
Welcome to the ASR forums, glad to have you..Is there an difference in bass authority with difficult speakers using M27 vs ATI 52X? Who have the "best" definition and weight..
Sorry for my lack of HIFI lingo
I think if you listened to them under blind, bias controlled conditions those differences would disappear.I have one other amp with me that also uses Ncore and they do sound a little different. Its hard to describe the differences but they are there but small. I still like the ATI but im curious about the Nad. Guess I just have to try
The ATI uses a traditional linear power supply; I can't find information on the NAD's power supply. Realistically, in normal operation the two should sound identical. In the low end, the linear power supply could in theory behave differently with a rough speaker load than a switching power supply, but I think you'd be talking about rather unique cases where this might have an impact. One reason ATI went with linear supplies was the availability of higher peak output current from a transformer than a SMPS (at least at the time). The ATI also has an auto-ranging AC input voltage selection circuit controlled by a microcontroller. The advantage of this is that the amp is protected in real time from things like brownouts / over-voltages; normal operation resumes when the AC line is back in spec at either 120VAC or 240VAC. The ATI also has a (user defeatable) sleep mode which takes the modules into low power mode after 10 minutes. One of the main draws of power with the NC500 modules is heat dissipation in the output inductor during no signal. Sleep mode gets around that.Welcome to the ASR forums, glad to have you..
No need for fancy HiFi lingo here, we don't get involved in that type of thing.
Both these amp use hypex n-core output modules and I would bet you that in a blind, level equalized listening test you'd never be able to identify any differences whatsoever.
NAD rates it at,Does the Nad M27 drop in power with all seven channels driven?
Line voltage shouldn’t be an issue in uk @240v?NAD rates it at,
So even if it make spec, yes it will drop in power from want Amir measured here a small amount.
- Continuous output power into 8 Ohms and 4 Ohms
- ≥180W (ref. rated THD, 20Hz-20kHz, all channels driven
Then there's the issue of line voltage, most typical home power outlets voltage will begin to sag at this level of demand and the max power out along with it. I see nothing here to be concerned about. I can't imagine any multich source that would ever require full power on all channels at the same time.
Ah, that doesn't show in your profileLine voltage shouldn’t be an issue in uk @240v?
