maty
Hypex NC1200
There's apparently been a revision since Audioholics reviewed the Monolith, because new models have XLR inputs! Monoprice has RCA-only refurbs, but I don't consider the discount nearly big enough.It would be interesting to see how the Monolith 7 would test since I think Gene actually tested the Monolith 2.
Then, why the SINAD is much better than Nord One NC500? 5 dB more. Worse implementation? Discrete/boutique buffers? Measurements from XLR both. Nord only has XLR inputs.
https://www.audiosciencereview.com/...-and-measurements-of-nord-one-nc500-amp.7704/
Initially designed by Sonic Imagery
BTW, the PURIFI 1ET400A kit has an evaluation board (with buffer) too.
Very kool and great timing. Looks like the M27 has lightened the mood around here on the multich gear. LOLYes, at US $4,400 it is not cheap but you are getting 7 channels of amplifications. That is roughly $630/channel which is actually quite competitive.
I am probably drunk but from good measurements and great looks of NAD M27 but I am happy to give it one of my highest recommendations.
If you have a home theater and want a gorgeous, powerful and performant multi-channel amplifier, your search is over. Get the M27 and worry about money for food later.
And while a bit pricey, to really best it would take $12,000 for 4 AHB2's, on the lab bench that is.
Sal, an Emotiva XPA Gen 3 could be arrangedThere are a number of good multich amps out there from ATI & Monoprice to Emotiva for less that deserve attention if they can be acquired.
I wonder how using the M27 to bi-amp all three front Left, Center, and Right speakers with the 7th amp unused would affect everything you mentioned...Before everyone gets too excited about this amplifier, bear in mind Amir can only test 2 of the 7 amplifiers. These numbers are absolute best case.
We know continuous power will drop right off, dynamic (burst power) will collapse and overall THD will skyrocket with more channels driven. That said, the unit sure looks to be a lovely looking product and in real terms reasonable value IMO.
@orangejello, could you elaborate on your experience with these two amps? It would be interesting to see whether the M22's measurements are not too far behind the Benchmark's, while having more power.From my experience with the M22 vs AHB2 ...
