silver2545
- Joined
- Oct 17, 2019
- Messages
- 9
- Likes
- 0
It is best used as a combination unit. Adding an analog source will harm overall fidelity rather than increase it, due to the additional analog>ADC>DAC step. You are still using the internal AK4493 DAC after all, with an additional digitizing step...@amirm Oh so the XLR inputs on the Monolith go to the ADC and messing up the audio? Thats a little disappointing I suspected that might happen but wasnt sure. So getting the M500 would not really pair with it well?
THX aren't all the same.To the question about using this as a DAC feeding to another headphone amp, there is no headphone amp that will improve performance except when getting into things of significantly higher power like the Benchmark HPA4. The THX amp in this device is very similar in performance to the other THX amps tested here, making it one of the very best at any price point. The dac is the factor most limiting to performance on this device. But you can't use a separate dac with this to increase performance either for previously stated reasons.
Using this as a combo unit with no extra components is the best way to use this. Anything other configuration would either be a downgrade or a waste of money in my opinion.
Hello- havent posted before but I just got a new THX 788 from monoprice, and when i plug in my edition XX over balanced i get the error code "temperature protect" and the unit turns off. I then have to unplug, replug and re-turn on the unit. SE works fine, and balanced from my M1070s works fine. Any ideas?
I was going to return it and get the 789, but apparently I can only exchange it so I guess I am getting another one sent to me will see if it does the same thing, kind of disappointed already and would rather just have something else tho.Try to get the Massdrop THX 789; I've had one for over a year now and have no issues. Probably 1000hr listening time now too!
How do they not let you return it? Are you outside of the return window or what?I was going to return it and get the 789, but apparently I can only exchange it so I guess I am getting another one sent to me will see if it does the same thing, kind of disappointed already and would rather just have something else tho.
It is kind of funny because they are now sending me a replacement without recieving the first one saying "if the item is not sent back original card will be charged adidition $530" I may just keep them both and let them charge the card I no longer have, just for being assholes about it.How do they not let you return it? Are you outside of the return window or what?
Bought it through Amazon which is why I thought they would be able to just put it onto my gift balance like everything else they have ever refunded me, but they said original card only or exchange it for exact item. Everything I have ordered directly from Monoprice has been easy, even sent something in for warranty to them before no problem.Were you not allowed to exchange for the THX aaa 887?
Can you try optical input to the DAC? That would show if it's a ground loop coming from USB, or if it's the unit itself..Am I doing something wrong? I got this and ever since I had it I can always hear a pink noise, consistent with my FiiO FH5s I thought maybe a groudloop or some sort, so I tried the ifi silencer no luck, then added a ifi idefender and changed the USB cable, and even tried a different computer. Is this normal for the Monolith? (Btw this is my second had to return my first one since the power adapter broke after one use.) Did I just get two bad units? They both sounded the same.
I had similar problems and ended up using an optical cable. Problem solved.Am I doing something wrong? I got this and ever since I had it I can always hear a pink noise, consistent with my FiiO FH5s I thought maybe a groudloop or some sort, so I tried the ifi silencer no luck, then added a ifi idefender and changed the USB cable, and even tried a different computer. Is this normal for the Monolith? (Btw this is my second had to return my first one since the power adapter broke after one use.) Did I just get two bad units? They both sounded the same.
Using FiiO FH5, I'll try optical once I get a DAC that outputs to optical. Thanks!Can you try optical input to the DAC? That would show if it's a ground loop coming from USB, or if it's the unit itself..
Also what are you using for listening, what headhones/earphones?
