- Joined
- Apr 8, 2019
- Messages
- 163
- Likes
- 212
Major flaw of the SHD is a lack of home theater bypass option for the analog inputs for front left, right and subwoofer. This is the only reason I won't buy one and I haven't heard of any work around solution other than some type of manual external switcher. So, if you are planning to listen to music in the same room you watch movies you might want to consider the Anthem STR Pre-amp instead.
use an external switch , will be less noise than a preamp ht bypass anyways, one was reviewed here
