As I recall, both tested were the non-FF version (at least mine was). From what I know about FF, it might make a small difference in the distortion or noise measurements (less in mids & treble, more in bass). And FF substantially increases the available output power under most conditions.
To explain: FF is Meier's "frequency adaptive feedback". It is a kind pre-emphasis, similar in concept to the RIAA curve for LPs, or the optional pre-emphasis in the redbook CD standard. Imagine an EQ that attenuates bass and levels off flat in the mids/treble. It is applied to the analog input, before the amp's gain-feedback loop. Then the reverse EQ is applied after the gain-feedback loop, before the amp outputs. The idea is to emphasize the most hearing-sensitive frequencies in the amp's gain-feedback loop, while retaining flat overall frequency response. Since the amp's gain-feedback loop determines noise & distortion, it's a way to psycho-acoustically shape the noise-distortion profile. At least that is how I understand the idea, from Meier's
description.
Another effect of FF is that it partially mitigates the voltage clipping that limits the Jazz max output level, enabling it to play louder before that distortion kicks in. As I understand from the detailed discussion here (in which Meier participated), this clipping is a voltage limitation of the resistors used in the gain-feedback loop. Most of the overall amplitude of music is in the bass, so reducing bass reduces the overall voltage of the musical signal. The reverse EQ is applied after the gain-feedback loop, so the gain-feedback loop resistors never see the full scale signal, which means it doesn't clip. So, how much more voltage & power the FF Jazz can produce, depends on the frequency spectrum of the music you listen to. Mid-treble frequencies above the FF curve will not be affected, they will have the same max output level as before. Lower frequencies will have a higher max output level - how much higher depends on the shape of the FF curve. Meier
quotes 3.7 V max for the non-FF Jazz (across all frequencies), which is about what Amir measured. And 15 V at 200 Hz, so about 12 dB louder in the bass. That difference gives some idea of the shape of FF curve: it's down 12 dB at 200 Hz.
