Review and Measurements of Massdrop x Grace Design SDAC
sophie smith
Thanks.
I would jump on it, but with US shipping/currency exchange rate and the fact that JDS said they will do Black Friday sales again I am tempted to wait and see what happens in November.
caguilar91
This is a review and detailed measurements and comparison of Massdrop Grace Design SDAC DAC. It is on kind loan from a forum member. The "drop" is over but when it was active, the unit costs $79. See it, and the detailed specs here: https://www.massdrop.com/buy/massdrop-x-grace-design-standard-dac.
The unit is similar size to JDS Labs OL DAC ($99 plus shipping) which I compared it to in this review:
Clearly they are after the same market and audience. While both have decent heft for what they are, they are both too light so support heavy cables and such.
The JDS OL DAC comes with an external linear power supply while the Grace SDAC is USB powered. The designer, Michael Grace, has written a nice post about the SDAC here: https://www.massdrop.com/buy/massdrop-x-grace-design-standard-dac/talk/1806625. Reading that, seems like good engineering has gone into the device beyond just slapping a reference design in a box. Measurements of course will tell if that is, or is not the case.
The unit is UAC 2 compliant meaning it worked without installing and drivers in Windows 10 Creators edition. I tested it as I do all other USB DACs using Roon in "exclusive" WASAPI interface which gives bit-exact access to the DAC.
I am sure you are anxious to see the measurements so let's get into that. If you are not familiar with my measurements, I suggest reading my tutorial on audio measurements here: https://www.audiosciencereview.com/forum/index.php?threads/understanding-audio-measurements.2351/
And oh, unless I specifically say otherwise, I have no relationship to these or any other manufacturers.
Measurements
Let's start simple and look at frequency response measurements using 48 kHz sampling:
I was surprised to see that early roll off in OL DAC's response starting at just 10 kHz. The graph has very fine scale so that is not a large drop but still, at 48 kHz sampling, I expect to see pretty flat response to 20 kHz which the Grace SDAC delivers. Importantly the SDAC has higher output which may be necessary to drive some power amplifiers to their maximum output. The SDAC output is 2.16 volts RMS whereas the OL DAC was 2.00 volts (@ 1 kHz).
Channel matching while not an issue, was slightly worse on SDAC than OL DAC as you can (barely) see in the graphs.
Next let's look at jitter and noise with a 24-bit, 48 kHz signal. Everything other than the main tone at 12 kHz is undesirable:
The Grace SDAC nails this test with a flat, low noise floor free of any distortion or noise spikes. The OL DAC does nearly as well but its noise floor is a few dB higher and we see widening of the 12 kHz "skirts" which indicates some amount of random jitter. Mind you, these are all, literally in the noise and the OL DAC response is very good. Still, in a race to best engineering, the SDAC wins here by a bit.
Linearity test is the favorite for everyone so let's see how they both did:
Both provide good performance but the SDAC again pulls ahead by a bit. The same is reflected in time domain response of a low level, -90 dB sine wave:
Next let's feed them a 1 kHz tone, filter that out from their output and see what remains:
While the SDAC shows lower noise, in a reversal of fortunes, it has higher harmonic distortion than the OL DAC. Some or all of this may be due to higher output it provides. I had no good way of taking that effect out of that this test.
Let's look at how the harmonic distortion and noise act versus level:
The OL DAC shows a lower (but insignificant) amount of THD+N than SDAC. Both display a bit more distortion close to their maximum output level. Note that these are at 400 Hz rather than the more common 1 kHz (limitation of the test file I am using at the moment).
We have a bit of mixed picture in the measurements here relative to the two DACs under test. Overall though, I would give the nod and recommendation to Grace SDAC for exemplary jitter response, lower noise floor, higher output and flat frequency response. Its harmonic distortion is higher than I like but in this price bracket and audibly, not a concern.
It is clear there is good engineering behind Grace SDAC. It is also a good value at just $79 from Massdrop. Alas, you can't buy the unit right now so take that into account when deciding what to purchase.
Edit: fixed the comment about output levels and updated the measurement/graphs for THD+N.
As always, questions, comments, corrections, etc. are all welcome.
If you like this review, please consider donating funds for these types of hardware purchase using Patreon (https://www.patreon.com/audiosciencereview), or upgrading your membership here though Paypal (https://audiosciencereview.com/foru...eview-and-measurements.2164/page-3#post-59054).
Wondering how much SINAD does it get? As it would be nice to compare a bit between Topping D10 and D30, Modi 3, OL DAC and other ~$99 DACs as the best option to pair it with the new JDS Atom Amp. Also it seems that this price range as of lately has been the major focus from big brands and even being better than their TOTL offerings, as the JDS Atom outperforms the Element (and also in THX AAA 789 territory, unbalanced vs balanced however) and the Schiit Modi 3 being miles ahead of every other underperforming DAC from Schiit including the extremely overpriced Yggdrasil. And maybe I might suggest some kind of Wall of Fame on the different price ranges as I remember from Innerfidelity. :D
gz-
hey! i'm new here, that's a great idea, many people would appreciate if it could be done "the battle of the $99 DACs" schiit vs jdslabs vs smsl vs topping vs grace etc etc all in one review!
I hear you but it is a lot of work. :) And would slow down reviewing new gear. Let me think about it.
maxxevv
It would be quite the reference material for anyone going into audio on a tight budget!
caguilar91
It's very interesting how entry level gear is becoming as good (or almost) as very high priced DACs and Amps, so maybe those that get your recommendation should be added to a list with the most important measurements and price for comparison, just an idea! :D I would love to more easily determine which DAC at the moment would be the best match for the JDS Labs Atom Amp, which is definitely the best I have seen at around $100 mark, maybe the Schiit Modi 3 (even though that stack would look funny) is the best at the ~$100 mark, but not so far the Massdrop x Grace SDAC and Topping D10/D30 that might look a bit better haha.
PuX
headphone.com had a fantastic build a graph page that lets you pick headphones and compare frequency response.
it would be great to use something similar for dacs and amps. obviously it would require same conditions for every device, which might be impossible in some cases (i.e. voltage can't be matched, one device outputs 2.0V, another one outputs 2.1V).
I have thought about that. It requires custom web development as our forum software obviously can't do that. For now, the bar graphs I am publishing are a substitute for that.
Part of the issue is that a number of DACs have been on loan and no longer here. I will have to think of what I have personally that is $99.
Jimster480
Tampa Bay
Amir has flipped the audio scene on its head!
Products are competing for the top measuring spot on this forum!
On top of that mfg's are pulling no punches with their best designs being priced out to the masses, they must realize that this is where the money is after seeing the Schiit sales figures on their poorly measuring gear!
Thats quite alot of Schiit junk to be replaced in the next year(s) now that its been proven to be junk!
caguilar91
The only worthwhile Schiit is the Modi 3, which happens to be the cheapest and all their other DACs are complete flops, and the Magni 3 is just so-so but still much better than the Jotunheim. And well, that's just Schiit haha. But now, JDS Labs introduces its Atom Amp and is much better than the Element (and EL Amp) and just happens to be much cheaper, as the OL DAC compared to the Objective DAC and so on... Really, times have changed and now entry level gear is much better than many TOTL offerings and almost on par with the best measuring gear. Oh, what a great time it is to be an audiophile! :cool:
Jimster480
Tampa Bay
Yep! This trend has really accelerated this year as this site has become quite known and popular!
I'm just glad to have been even a small part of this revolution; spreading the word about this site everywhere I can.
DuxServit
The key aspects of ASR that diffentiates it from others are, IMHO:
— “Standardized” measurements method applied across products.
— Measurements are reported graphically in a uniform manner, with very useful annotations.
— Equipment are loaned by individuals or purchased by Amir.
— The ASR site is not literred by advertising banners.
