Is your volume too high? I've never had this amp clip.My amp is clipping in gain 2 / II / Mid gain, With SMSL M500 mk1 as a dac via XLR Cables and Hifiman HE-R9 headphone on XLR or stock SE cable. At a certain volume of course, but for music i would like to pass that volume sometimes...
Is also a strange thing that it reaches the same volume on gain III before clipping?
What in the world..??
It happens even with RCA's by M500, in every gain!!
Depends on how much voltage is too much.... Is that specified?The manual states I may experience clipping if I run too much voltage in from the DAC at the III gain position. Should I be using a lower gain setting or attenuating the DAC? I'm using a SMSL DO100 Pro at max volume with XLR cables.
Input sensitivity when gain set to "III" is 2 V RMS regardless of used input (SE/balanced).Depends on how much voltage is too much.... Is that specified?
I think I noticed the soft clipping when running the DAC at max voltage with the gain set to III. It sounds better reducing the DAC to 74 from 99. This sounds different from running the DAC at full volume and using the gain setting of II. Which is better?Input sensitivity when gain set to "III" is 2 V RMS regardless of used input (SE/balanced).
Better is to use the lowest amp gain that allows to achieve your desired volume level. I would also prefer to adjust volume at the DAC side to avoid pot artifacts.I think I noticed the soft clipping when running the DAC at max voltage with the gain set to III. It sounds better reducing the DAC to 74 from 99. This sounds different from running the DAC at full volume and using the gain setting of II. Which is better?
Revisiting this. I actually don't think I hear distortion going full volume from my DO100 Pro DAC (balanced) like I thought I did previously, when using the III gain setting. I am using a balanced headphone cable too. The III gain setting sounds best to me. The manual is confusing about whether or not I should be doing this. Can someone clarify?
The explanation given above was accurate, but if you are happy with what you're hearing then no need to overthink it. Listen and enjoy.
There is nothing confusing about the text in the manual. Also, posts #1646 and #1648 do provide a detailed answer to your question. No need to repeat it again and again. Respect your fellow members and do not overflow this thread with the same questions you have already gotten answers for.Still confused, please help.
From the manual of the amp:
From the manual of the dac:
I'm using the XLR to XLR. If the DAC is outputting 5.2Vrms this is under 7Vrms so then no need to attenuate, right? Then why the recommendation to use setting II instead of III? Wouldn't 2.1V be for single ended? Still confused, please help.
I read this thread and couldn't make sense of it. What gain do you use with your E50? 1, 2, or 3?This post is a good breakdown that I've referred to for my own 789. My E50 puts out 5V and I listen on his gain with no issues.
Same thing here. I have the Monoprice variation, but have essentially the same answer.To answer your question, I've used all of the gains over the years based on whatever I felt was needed to achieve the volume and sound I wanted.
How do you match the levels to come to such a conclusion?to match the same level!
with the volume knob.How do you match the levels to come to such a conclusion?
You should use a voltmeter.with the volume knob.
www.audiosciencereview.com
