Review and Measurements of Lyngdorf RoomPerfect EQ
You need to add any delay from the electronics in the sub to the distance measurement. This data should be available from the sub manufacturer.
What is the best way way of integrating two SVS subs using Room Perfect? The Lyngdorf Going Deep Video states to use full range outputs with a low pass (as opposed to LFE) for best results. The only way to bypass SVS DSP is using the LFE. The SVS DSP adds about 6 ms time delay. Would I add 6.76 feet to my measurement to account for the 6 ms time delay?
Since the DSP will be turned on with this connection - can I use it to set level, phase, and built in dsp to integrate as best as possible prior to running room perfect for the best results?
The video I was referencing -
Lyngdorf doesn't adjust automatically delays and phase, which is crucial for sub integration. Phase is also not manually adjustable at all on Lyngdorf side . You can't adjust levels separately for each sub from Lyngdorf either.
All RP does is EQ across the range.
The best way would probably be connect to LFE (the one which still does processing)
1. finding correct delays manually using REW or MSO and setting them on lyngdorf side
2. finding levels manually using REW or MSO and setting them on SVS
3. finding phase settings manually using REW or MSO and setting them on SVS
4. finding xover settings manually using REW or MSO and setting them on lyngdorf side
And then run RP
